Need help with tire sizes
Hey guys, I piked up a set of 19" RUF replica wheels. 19"x8.5 and 19"x11. I have been trying to find a size that will work, the fronts are easy. Can use 225 or 235/35/19. The rears are being a PITA however, the ideal sizes would be either 295/25/19 or 305/25/19 which are not available in NA. The seller seems to know about wheels and he suggested that instead of going off of the factory rear size (285/40/18) i use the winter rear size of 265/35/18. When I use the 1010Tire calculator it says I can use a 295/30/19 with a variance of 2.65% which is within the 3% spec. Anyone have any experience with this? I think the viscous couple is more forgiving than the PTM but I want to make sure I don't fry something. Thank yo in advance!
Are you saying 2% difference from front to rear or from stock size to the 305? I was told by my techs and parts dept that we can only go 3% difference from stock size to the new size. I have been having a heel of a time finding something that fits that profile. a 315/25/19 works perfectly but they don't make them in NA, only Europe which would be a pain to get. You have been running this combo with no issues it seems? I wonder if it will cause the speedo to be out or any issues with the viscous coupler?
Boost Junkie
Issue w the 3% difference is front to rear of whatever is on the car not difference from stock. With those sizes the speedo reads a little slow. The 3% is to protect the viscous coupler
if they are telling you that I’d find new techs
