996 wheels on a 993
996 wheels on a 993
Hey Guys,
I've seen 996 wheels on 993's but I want to make sure before I buy them. Is it a straight bolt on, offset the same?
They are size 18x8.5 in the front and 18x11 in the rear. The offsets are ET30 and ET45 respectively
If they are 996TT wheels, I believe the fronts are 18x8. They will bolt on and fit nicely on a widebody but will not fit a narrow body in the rear. I had these wheels on my 993 C4S and I believe Viperbob is running them on his 993TT.
Keeper of the Truth
Factory 996 Turbo front: 8" - ET50
Factory 996 GT2 front: 8.5" - ET40
Thanks for the replies. It sounds like it's no issue. These are actually HRE wheels off a 2001 turbo.
Crap, looks like the auction just ended.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2451687206
Here is some info on the 993 hollow spoke wheels:
Each front wheels weigh 19.95 lbs ( 5.62 lbs lighter than solid spoke Turbo wheels )
Front wheels are part # 993.362.136.00 ( 8" x 18" - ET 52 )
Each rear wheels weigh 25.13 lbs ( 5.95 lbs lighter than solid spoke Turbo wheels )
Rear wheels are part # 993.362.140.00 ( 10" x 18" - ET 40 )
Hi bob,
If you don't mind, could you post another pic with the rear wheel and one for the whole car?
I am having trouble seeing your pics in .dat format. tks!
edrewitz,
I believe Viperbob also runs with a 5mm spacer in the rear. RIght bob?
edrewitz,
I'm waiting on a new rear wheel to arrive from Porsche so I can put a set of '04 Turbo take offs on my 993 Turbo.
I hope it gets here soon so I don't blow my PSS9 money on more exotic wheels. My logic is that I can put the 996 wheels on my Boxster S at a later date...
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I like the look of the 996TT wheels on the 993. Wish they fit a narrow body as I always see them for sale at reasonable prices..
