993 Turbo Forum 1995-1998
Speedometer Needle Drops to 0 while driving
Old 05-20-2009, 12:08 AM
Knut993TT
Knut993TT's Avatar
Default Speedometer Needle Drops to 0 while driving
Since I bought my car some 8 years ago the speedometer has had a tendency to drop to 0 while driving normally down the street. It stays at 0 for 2-5 seconds, then jumps back to normal gain. During this period, the ABS & ABD light comes on. Until this spring, it only happended 2-3 times during a season and I considered it to be a minor issue. This year however, it happens all the time. I have a basic OBD-2 code reader, but it states there are no error codes.
I assume one of the wheel sensors is giving me some problem. Do I need a code reader with a particular feature to access this data?
tnx
Knut
Old 05-21-2009, 07:17 PM
trabi996
trabi996's Avatar
Default ground
Seems like a ground issue to me.....
Old 05-21-2009, 07:26 PM
Barney1
Barney1's Avatar
Stop testing out the great brakes...... Just kidding... I've never heard of that..
Old 05-21-2009, 07:33 PM
Texas993
Texas993's Avatar
In a ferrari that was a sign that the alternator was going bad. Check your battery connections.
No power loss or change in engine performance?
Old 05-22-2009, 09:58 PM
Knut993TT
Knut993TT's Avatar
I will check the alternator and battery connections, just in case. However, other instruments and radio etc, operates well while the problem occurs. With regards to poor connectivity, there is no correlation with driving over rough vs smooth surfaces. Given the ABS & ABD light comes on, I assume the computer is detecting an input sensor issue and as a result disconnects the ABS circuits.
Old 05-13-2010, 05:10 AM
Trevor-uk
Trevor-uk's Avatar
Hi Guys
I'm resurrecting this thread to see how and if the OP solved this or if anyone else has seen (and solved) this issue. It has just started to happen to my '96 C4S in the same manner - speedo drops to zero, ABS and ABD lights come on. I have noted that it can occur on uneven road. Speedo may spring back to life at any time while driving but warning lights stay on until ignition switched off and on again. No other driving or electrical function appears affected.
Is there a particular sensor that contributes both to the speedo signal and the ABS and ABD monitoring?
TIA
Trev
Old 05-13-2010, 01:50 PM
ScottMellor
ScottMellor's Avatar
Was the wiring harness recall done?
Old 05-13-2010, 02:03 PM
BHMav8r
BHMav8r's Avatar
Received 2,647 Likes on 1,673 Posts
Have you checked the fuse? Sometimes the leads that hold the fuse get spread apart and the circuit becomes intermitant, +1 on the battery connections - good luck.
Old 05-13-2010, 02:59 PM
Trevor-uk
Trevor-uk's Avatar
Wiring harness recall done.
Battery connections and fuse to check - no.16?
Old 05-23-2010, 07:14 PM
Trevor-uk
Trevor-uk's Avatar
Battery ok, voltage ok, fuse ok.
My research has pointed me towards the left rear wheel sensor as the source of the speedo signal (and contributor to ABD and ABS signals) - can anyone confirm this?
Is this a likely candidate for failure? I am unable to measure any difference statically from the others - around 1.75k ohm with some movement if the wheel is turned. Am I barking up the wrong tree?
Trev
Old 08-25-2015, 12:05 PM
chuaed
4th Gear
chuaed's Avatar
Trev
I'm experiencing the same issue with my speedo recently. Speedometer drops to zero on occasions with ABS and "!" light flashing intermittently.
Has anyone established the root cause of this fault recurrence?
Ed.
Old 09-03-2015, 04:36 AM
Knut993TT
Knut993TT's Avatar
For my particular issue, i was able to narrow down the problem to rear driver wheel sensor. I replaced the sensor and years of agony was gone. Used a hairdryer to warm up one sensor at the time until the light came on in dash.
Old 09-06-2015, 10:49 AM
chuaed
4th Gear
chuaed's Avatar
Thanks, i will look into / replace the wheel sensors. Fingers crossed this solves the problem!
Old 02-17-2018, 08:33 PM
jarhed123
4th Gear
jarhed123's Avatar
Bringing this post up again because I am having the same problem with my '99 996. The ABS light is on and the speedometer drops to 0 for a few seconds before coming back to life, and the cycle repeats itself. I would like to know which wheel sensor it was that you guys have been replacing. The only sensor I notice is the brake sensor. Thanks
Old 02-19-2018, 02:55 PM
ronnie993tt
ronnie993tt's Avatar
Or you can do nothing, drive as fast as you want, blame it on the speedo when the tax collector stops you............
Quick Reply: Speedometer Needle Drops to 0 while driving
