Frequency of oil changes on low use vehicles?
Is it wise to do yearly oil changes on low use vehicles that are not driven much and kept in climate controlled buildings?
Take for instance a large Porsche collection in which the vehicle might be moved on a few times a year.
The oil viscosity will likely not break down. Other factors such as moisture may come into play?
Sure. It's cheap insurance to change the oil once a year on a vehicle that doesn't get driven much, especially if you have the means to afford and entire 'large Porsche collection".
I change the oil in all my cars annually just to be safe...can't ever hurt to have a tech look over the car once per year just to keep all working perfectly
button queen
Annually way less than 2K miles per year. I change oil every two years at the same time I have the car up for brake fluid change. Driven often every month and plenty often to avoid dried seals and animal nests in the engine bay!!
A newer Corvette that we own that my wife uses gets driven less than 2,000 miles a year.
These cars have an "oil life" gauge that gives a % of the oil life left. I didn't change the oil last year and it says 79% of "oil life" left.
My guess is that it measure the viscosity only.
No Porsche collection of any type here - 1 toy is enough for me.
The biggest detriment to oil...and engines...is short trips or starting just to move around the garage w/o getting the oil up to temp. This creates moisture by condensation. Even though you don't put on a lot of miles in a year's time, if the vast majority of your trips are of 15-20 minutes or more, your oil is going to be just fine by changing every two years.
sacman (07-19-2023)
RL Technical Advisor
Engine oil should be changed annually, regardless of mileage unless the vehicle is stored in a temperature & humidity controlled environment (such as a museum).
Its all about corrosion control due to condensation and its cheap insurance against bearing damage.
"stored in a temperature & humidity controlled environment"
Yep, thanks to my wife for finding this "garage with a house on top", we have room for 7. The temperature in the garage goes from a high in the Summer of 75F to a low of 58F in the Winter. Have never seen humidity get higher than 70%, normally 60%.
I do it once a year when Mobil 1 has a promo $15 off on 5 quarts, saves $30 at oil change for our cars.Buy the oil at Wal-Mart. If out of stock I order in on their website for in-store pick-up. I Use OE oil filters. Not sure oil filters need to be refreshed with each oil change but I do it anyway. Creature of habit!
At less than 1k miles per year and reaching full operating temp every drive, change M1 V Twinn, filters and brake fluid every 2 years. Chats with M1 techs on 2 occasions indicate I'm wasting my money. Go 3 or 4 years. Apparently humidity matters for storage but not temperature. If brakes aren't rusting, humidity is fine.
I drive about 5 - 6k miles/year, change the oil every 2 years. Uses about 1qt to top it off. Even then, oil's still light brown in color. I see no reason to change it earlier. Castrol edge 10/60
