Rear Links Questions
I am considering installing the ERP adjustable rear toe links, camber links, and kinematic links. Is it necessary to do them all at the same time? If it is not necessary to do them at the same time, is there a sequence in which they should preferably be done? Does one or the other make a bigger impact?
Is this a track car?
The complication here is the built in flex of the stock rubber bushes
the RS used stiffer rubber bushes on arm #4 (caster) and the trailing arm#5 (A-arm). The leading leg of #5 has a mono-ball stock. This limits KT change caused by rotation around the line which all of the arms intersect, #4 being only a little stiffer than stock causes only a small reduction in KT change. The bulk of KT change is from #5, the stiffer. RS bush there causes a lot of reduction in KT change.
The RSR uses mono-***** on all the arms, so while there is still toe channe due to suspension travel, KT change is eliminated. On theses the amount of KT change is dependent on caster adjustment, more caster = more KT and vice versa. on the Motorsports KT gauge 3.5 is a good place to be, as you go down from there the rear of the car gets twitchier and twitchier, at some point it becomes scary.
I'm unsure of the effect of changing #3 & $ to mono-ball piece meal.
here's what I have run
RS #4 & 6 stock everywhere else - great street setup
RS #4 & 6 & mono-ball #2 w/ locks - great track setup, on the street it makes bump response more immediate/jerky and noticeable, some will not like this.
RSR #5 & Rennline mono-ball#3, 4 &2 - this is a great track setup, the main reason I went to this was that the stock eccentrics would walk in heavy track usage, the car would become undriveable after an hour or so. I don't notice the jerky bump response that was observed w/ the RS setup. Don't know if this was eliminated or if I just don't notice it any more, I believe the former but am non sure.
Rear Links Question
Bill, thanks for the excellent tutorial. I believe that I have purchased all of the rear suspension parts that are unique to the RS. So if I understand you correctly, you are saying that with the RS parts installed, I don't need the ERP adjustable toe, camber and kinematic links for street use?
