993 Forum 1995-1998
I have a theory about Distributor Failures
Old 06-03-2017, 09:05 PM
NYC993
NYC993's Avatar
Aren't bearings sealed with grease inside? What are we oiling with motor oil exactly? and why motor oil?
Old 06-25-2017, 06:06 PM
pp000830
pp000830's Avatar
Received 1,441 Likes on 1,015 Posts
My theory is that the seals on the bearings do not seal up well after 20 years.
I use motor oil because;
  • that is what I have,
  • it is heat resistant,
  • it is the lubricant for the bushing shaft bearing at the base of the distributor and
  • as a liquid it will flow downhill onto the bearings if present in the housing.
  • It is also what everyone at one time used to lubricate the distributor when things were regularly opened up to replace or adjust points.
Old 06-25-2017, 06:42 PM
PiB993
PiB993's Avatar
Is this why I hear a momentary squeak (belt slip?) on start up if the car has been sitting for a few days?
How do you oil yours? While it is disassembled or in the car?
Old 06-25-2017, 11:38 PM
AOW162435
Seared
AOW162435's Avatar
It's a toothed belt.
Andreas
Old 06-26-2017, 12:05 AM
nine9six
nine9six's Avatar
Peter,
Andreas is telling you to pick another belt for the squeal you hear. Most likely one of the Vbelts squealing. ; )
As far as lubing the distro shaft goes; I can't imagine a couple of drops of motor oil would last as a lubricant for the bearing, any longer than 15 mins., if even that long...Gravity being what it is.
Just my $.02
Old 06-26-2017, 03:15 AM
PiB993
PiB993's Avatar
Pictures would sure help. I thought someone also mentioned the alternator bearings as well. I am very unfamiliar with these engines. The distributor is gear driven going into the block on a TJ Jeep inline 6 I had a leak where it went into the block. We thought it could have been the dented oil pan, rms or any number of places but it was where the distributer went into the block to get driven by the crank I believe. Ran fine leaking a little.
Would you not just replace the bearings or distributor in it's entirety?
Old 06-27-2017, 07:43 PM
AZ Targa
AZ Targa's Avatar
Originally Posted by JDHertz11
You've been here long enough to know not to bring up what "regular" motor oil is. Here we go again... ****...
Old 06-27-2017, 10:44 PM
pp000830
pp000830's Avatar
I doubt the squeak is from your distributor, most likely one of the regular belts. The distributor belt is a toothed belt and can't really slip unless it is broken.
Quick Reply: I have a theory about Distributor Failures
