993 Complete susp.Overhaul, Elephant, AST coil,Wevo+Tramont.RStribute
Thank you , me too. I searched for a while to find a clean well kept GR nb 96 to do this with. very happy with this one.
Thank you man, I appreciate the interest. This community is the best.
Thank You!! Yes sir, already did my own version of a gundo,rs,fister type deal. had the shop cut them open, gut packing, weld a connection tube and seal them back up. then did the exterior bypass as well. Don't know which combo that is but I thought it would sound good and it does. A Fabspeed cat delete X pipe is coming up shortly. ordered but they seem to be a 6 weeks behind schedule build time so I have to wait, unfortunately. Fabspeed wide ovals will be on in a couple days. I agree , I cant wait to hear it with the x pipe. these car sound so awesome.
Will do, the second we dial it in I will give you guys the feedback for sure. I was told they have been running them in europe for a little while with great feedback from the 993 crowd.
I opted for the single adjustable 5100 series, fully upgrade-able later on to 2 or 3 way's . full aluminum bodied... here is a quick run down off their website.
Floating piston design with high pressure nitrogen means no cavitation around the piston.
14mm diameter internal shaft.
44.5 mm diameter shaft struts, inverted.
Steel cylinder body shocks, inverted.
High end, track ready suspension.
Rebound adjustable (''Singles'').
Low friction seal.
Adjuster ***** permanently mounted on the dampers.
Rubber bushings for ''eye'' shock mounts.
Optional spherical top mounts.
Optional DLC Coated shafts.
Optional DDP piston (double digressive).
Rebuildable.
Optional custom valving.
Alex from PERFORMANCE EUROWERKS swears by AST. He runs them in his track car, clients track cars and street cars and says they are a quality product with very little trouble at all. "High quality" especially at pricepoint. I trust him so I thought why not.
Low friction seal.
Rebuildable.
Subscribed.
I'm heading down this road as well, only a little at a time. I will be a good grasshopper and watch and learn...
Subscribed
These look pretty! 5100 series. Did you order them with the top mounts front and rear?
http://astsuspension-na.com/index.ph...993-carrera24/
thanks, can't wait to give the feedback.
Subscribed
much appreciated.
much appreciated.
Calipers painted , lowered to RS height . Looks gorgeous , what a difference .
Looks so nice from the rear
AST 5100 adjuster
Old and new
Elephant away links
Full rear assembly ready to go back in.
Crazy the shaft diameter size difference .
AST 5100 adjuster
Old and new
Elephant away links
Got it back about a week ago and decided to go to town on the undercarriage . 4 bottles of engine degreaser , a pressure washer and 4 hours time. The results are incredible. Here are the before pics .
gunk heavy duty gel
Gunk foam x 2 bottles
one zep heavy duty engine degreaser
doing it all over I would have skipped the zep and used another bottle of foam.
Spray it on, let it sit for 20-25 min
put a rain suit on and get ready for a lot of fun. Very rewarding process. Pressure washer shreds the grease , cosmoline etc. takes some time but works.
Beats scrubbing
