Secondary Air
Parts #4 and #5 in Andy's diagram are reasonably easy to access with the airbox removed. A good DIY writeup is here: https://rennlist.com/forums/993-foru...eck-valve.html
My only add to Bruce's excellent writeup is that I find it easier to remove the airbox and MAF housing as one unit, by loosening the hose clamp on the opposite end of the MAF housing from the airbox. Once out, you can separate the airbox from the MAF housing using the twist lock.
I'm not sure I've ever seen a writeup on R&R of #14, but others may have experience.
From the catalog:
4) 993 113 245 01 shut-off valve
5) 993 113 250 03 check valve
14) 911 618 123 01 change over valve (-95)
14) 996 605 123 01 change over valve
No worries. It's not like you have a copy of the catalog PDF on every device you own just for quick reference. I mean, who would do that, right?
