Headlight technical questions
I replaced my HID system by LED bulbs. Just like my mufflers that don't sound loud enough I think the headlight still don't light enough!
I'm not a tech guy but I see there is a very thick and OPAQUE glass (see red arrow below) that "blocks" of diffuse the light. Is there something I could do to this part to have a brighter light? From my understanding, removing it would be equal to having high beam and I don't want that.
And by the way, why is there a level on the headlights (white arrow)?
The thick lens is part of the low beam light construction and needed for a correct light output pattern.
You could clean the lens if it is dirty. Beware, do NOT touch the reflectors. Even very soft paper makes scratches in the fraglie surface. Blow clean.
The spirit level is a US car requirement.
Cheers,
Tore
Cheers,
Tore
Done!
I removed the projector and cleaned it. The inside part was very dirty! Maybe you can see it on the picture where I cleaned only one half ...
I will wait before doing the other side. I want to see the difference tonight.
It was easier to remove it than finding my tools
Sorry for my English (2nd language!) But once you remove the whole assembly, you need to remove the cover (opposite side of the lense itself). Remove the bulb and then you will see 3 screws around the socket where the light was (3 torx 20). You only have to unscrew them and pull the projector.
I'm Looking forward to try it tonight. I had changed from HID to LED and didn't see much difference.
As a reference, theretrofitsource makes a projector upgrade for 993s with a clear lenses and a much better output and cutoff than factory. Not expensive and worthwhile upgrade. It's on my list for next year.
I saw it and emailed them (no answer yet). But I wasn't sure if I had to buy the whole xenon kit
How do you think theretrofitsource -
https://www.theretrofitsource.com/co...rsche-993.html
compares to this thread -
https://rennlist.com/forums/993-foru...-beam-mod.html
I read the brochure page and install instructions on theretrofitsource and was pretty impressed.
Thanks,
Dave
Thanks,
Dave
Thanks,
Dave
Hello Patrick, thank you for contacting us! LED bulbs are not an upgrade in 99% of applications, including yours. The technology is just not there yet. The RetroQuik kit is as straight forward as it gets for swapping your projector out with something up to the modern times. This would go back to using your factory HID system or you can replace it with all new components. This is going to be the absolute best upgrade and LED bulbs will also not work well in these projectors which are strictly H1 based projectors.
Originally Posted by drb930
71-3.0-911,
Thanks,
Dave
Thanks,
Dave
-Scott
