Door Window Trim Removal?
Does anyone know how to remove the strip of black molding that runs between the door and bottom edge of the window (#1 in the diagram)?
+1 yep use the plastic ply tools. It will pop up.
Brad,
I haven't had the need to remove the rear window moulding, but my link in post #8 describes the removal. Give it a try; just dont get ham fisted with it.
The 1/4 windows are done like this...
https://rennlist.com/forums/964-foru...to-remove.html
The clips you show are only used on the doors and NOT the rear quarters which are as I previously stated, screwed in with 4 screws per side followed by a seal of butyl tape under the extruded aluminium trim
I can and am happy to detail the process if required.
Last edited by deutschnine; 03-23-2017 at 12:02 AM. Reason: Spelling error on my part
The clips are for the door trim piece.
I posted a link that describes how to remove the rear quarter window.
Nothing to be scarred of and if you wish I can pop one of mine out tomorrow and detail the process with full pics. It takes no more than 5 mins per side and is very easy as the rear quarters ARE not bonded in mate
