Cleaning out the 993 parts bin.
As many of you are aware, I've sold my trusted 993 and am moving on to a 997 Turbo. So, I spent today going through all the spare parts I've accumulated over the years of 993 ownership, and offer them up here. Most of the parts are new and have never been installed. I priced them at about 50% of new parts costs to move them out. Please advise if you would like to see pictures. Here is the listing:
1. Sold 996 leather steering wheel. This is the popular 996 upgrade wheel for the 993. This wheel is absolutely perfect. No blemishes, no wear, and the stitching is perfect. Comes complete with air bag. $450.
2. Rosewood shift ****. Brand new and never installed, custom Rosewood shift ****. $200
3. 993 606 123 01 Mass Air Flow Sensor (Used) Works fine. $75.
4. Turn signal lights (Left and right. Amber. Used $25 for the pair.
5. Sold Bergvill FX Keyless FOB conversion w/ 2 fobs.Replace the costly and problematic OEM key fob with a new system. New. $50.
6. 944 606 116 01 Throttle Position Sensor (TPS). New. $75.
7. Sold F91 Solid State DME relay. Replaces the problematic mechanical DME relay that has been an issue in 911's for many years. Brand new. $50.
8. 999 611 929 20 Copper Ground Strap. New $7.
9. 993 612 365 01 Brake Pad Sensor. New. $7.
10. 996 605 123 01 Vacuum Change Over Valve. There are (6) of these valves in the Variorum control system. I have (2) brand new valves. $20 each.
11. Sold 993 615 227 01 Porsche OEM DME relay. Brand new. $30.
12. 993 Idle Control Valve, used but works fine. $50.
13. Hella brand 993 accessory pull switch. Comes with (3) different colored lenses for the switch light (green, amber, or red) New. $25.
14. Sold Fuel tank gas cap. Used $15.
15. Sold 993 511 331 00 993 Front trunk lid support struts. New. $15 each.
16. Sold 964 613 621 00 Window Switch. New. I have (2) at $25 each.
17. Sold 993 631 907 00 993 Headlight Gaskets. New. I have (2) at $5 each.
18. 901 641 541 00 Oil Tanke Level Gauge. New. $50
19. Sold Walrod Front Control Arm Bushing Set. New. $50
20. Pilot 6 inch fog lites set. New. $45
Hey Ernie...Ill take one of the window switches if still available. Just PM me how you would like payment.
