Looking for part number
Does anyone know the part number for the Connector Housing of the Rear Spoiler Switch found in the center console?
I mean the connector to where this switch connects to:
The female socket for the window switch is part of the door wiring harness, item 4 below. Pretty sure it won't be sold separately.
To save a few bucks I suppose you could look for a used wiring harness and cut / splice it onto yours if you're handy with soldering and heat shrink tubing.
Oops, sorry I missed that it was the spoiler switch, my bad. The spoiler switch (and female socket) is almost certainly NOT interchangeable with the window.
Same issue though - it's part of a wiring harness ie #1 below.
Hmm, could be, though it's a bit hard to tell from the drawings, for example the one from Pelican below. 993 is not listed in the compatible models, but that's not necessarily fatal.
If I were the OP I'd order one and try it out, the price is right and worst case if it doesn't work he's only out a few bucks. If it does work, he'll probably save a bundle.
Aribob, have you actually used this part to replace the 993 sunroof socket? If so, OP should be able to order with confidence.
This is the part I purchased last April for use with a Targa Top Switch that I used for my garage door mod. Not sure that it will fit the spoiler switch because the pin configuration may be different.
IIRC correctly, I found the part through the 964 PET, which includes electric connectors.
Pretty sure I have one of those socket plugs on a spare harness that's beem pirated already
let me know , $25 shipped with corresponding wiring order included ...Bert
Thanks a lot everybody that was what I was looking for, I am trying to replace the round switch in my 964 for the switch found in the 993.
Budge96, thanks for the offer, but I am writting from Spain, I guess shipping would prohibitive, I better ask through my local dealer. Thanks anyway
I'll be in Barcelona in two weeks.
I have some blank ones and you would probably need the pins to go inside. I don't know if you can take the wires from your connector and just put them into this connector.
I came across a few duplicate switches and the plugs your seeking
, I would likely add another $5 for our USPS flat rate to you ..
Let me know , thanks Bert
