Oil leak question
Oil leak question
So I had a top end rebuild done on the 993 this spring. Car is running great and using virtually no oil which I'm super happy about. Noticed however a few drips of oil on my garage floor (car never leaked before). Took it back to the shop that did the Topend and they said the cleaned everything up, drove the car and put the car on the hoist to see where the leak was coming from. They mentioned the case bolt was leaking. Forgive my ignorance however would this leak be a result of something done when the top end was done or is it purely coincidental?
Any advice would be appreciated.
Derek
Derek
Should be unrelated as the case is the bottom half of the engine. You can address the issue or not. your call.
That's unfortunate, but it does happen. This article may be of some interest. For what its worth both my 993's have through bolt leaks - just a matter of time before I do the overhauls. Good luck, and hold onto your wallet. http://www.instant-g.com/WordPress/p...h-bolt-leakage
Derek
Derek
brake cleaner is great for cleaning oil, spray it on wipe w/ a rag.
One everything is clean it's easier to see where the oil is coming from
Do the top of the shroud and under the intake as a common source of leaks is the intake manifold, oil tends to collect in the intake valleys and around the flap operators. This is particularly true when oil level is kept near the max and high revs are seen. I keep my oil levels towards the bottom to alleviate this.
Yup, totally agree with the oil levels. Got cars coming into the shop with "high oil consumption" - check the oil level and it's at the top or even over. My advice it to keep it at most 1/3 up the stick when fully warm. Most of the guys who do that notice their oil consumption drops dramatically. They also notice the car does not have as much of the "air cooled aroma" because its not consuming the oil. Much easier on the cats as well.
Some of these also use the oil level gauge on the dash - DO NOT BELIEVE IT UNTIL YOU CALIBRATE. You can do this by comparing the stick to the guage and understanding the difference, or by pulling the sensor during an oil change and bending the float rod to adjust. It takes time to understand what this gauge is telling you. Definitely done over a dozen sensor calibrations now ...
Cheers,
Mike
Cheers,
Mike
If the oil leak is not dripping on your exhaust and smelling up your car you might consider just leaving it alone. There may be a minimally invasive fix I am not aware of, especially if the leak is around a fastener.
I just got the same diagnosis when I took my car in at the end of this season. My car is currently getting a bottom end rebuild. Not cheap but I am promised to get all 272 hp back after the rebuild.
I have 113k miles on the car so maybe the timing is not that surprising??
