2016 / 17 Winter projects.... Whats yours?
With winter just around the corner (for me anyway) been working on the list of things that need to be done to the car, service items, upgrades, projects that were started and never finished etc..
Here is a brief list of what I am going to be working on, and a couple of teasers.
Some Brake Teasers
- Engine and Tranny Drop: Engine check over, valve adjustment etc
- Transmission Refresh: Still working on the budget for this one.... Not pretty.
- LSD Rebuild (Guard Parts)
- Brake Upgrade: Pics below
- Wheel bearing replacement
- Wheel stud upgrade (bullet head)
- CV Rebuild
- Vacuum pump for exhaust
- Transmission oil cooler
- Finish carpet/Interior strip and RS carpet Install
- Race floor mats
- Ceramic coat headers
- Rebuild and reformat forgeline wheels (replace cracked center, change offset to clear new brakes.)
- New rear swaybar bushings (melted the old ones hence ceramic for the headers)
- 993 RSR Throttle linkage (Thanks Juha!)
- + Other bits and pieces as I start digging in.....
Some Brake Teasers
Here is my list;
Fan override switch
rebuild window switches
replace all belts
front and rear windscreen seal
spoiler to manual control
chip
Wevo mounts
trans mount support
Brake flush after cycling ABS (on a slippery parking lot)
possible addition of RS eccentrics on toe arms, realignment
Fan override switch
replace all belts
chip
Wevo mounts
trans mount support
Agent Orange
My list consists pretty much only of maintenance and repairs:
- Oil change
- Replace remote battery
- Replace hood & deck lid shocks
- Replace broken frunk carpet clip
- Fix driver seat motor
- Fix sagging door pockets
- Fix turn stalk
- Fix alarm system malfunction (there is a short somewhere...)
And...
- Red seat belts - I've been thinking of doing this for some time but I'm not sure I want to spend $800 on it...
- Oil change
- Fix turn stalk
And...
Spoiler wall replacement. Sunroof seals.
Engine / Gearbox / Brakes - fluid change
replace tie rods
Want to remove and clean all ac servo's.
Not sure how realistic this is.
Take picture of speedo when it hits 95993!
replace tie rods
steven, what's a "vacuum pump for exhaust?"
TresDuro this weekend at Utah Motorsports Campus.
friday practice and saturday race is outer loop, east track, full track. race group is scored by points, time trial is combined time on all three tracks. sunday is full track all day. great chance to compete on three different track on the same day.
weather forecast is cool and sunny, no wind.
you should start driving now.
Some Brake Teasers
- CV Rebuild
- Race floor mats
Some Brake Teasers
I'm curious about this one - Vacuum pump for exhaust
and also the wheel change, as far as I know you have one of the more aggressive wheel/tire fitments on a n/b, do keep us in the loop.
Interesting about the cracked wheel, one of my Forgelines cracked in the center section, I had both rears rebuilt w/ new centers.
Exhaust Below.
Intersting list
I picked one up and tested it and it closes the valves perfectly, so need to do some wiring to my ECU and use that to control the valve just like the GT3, and have a "Sport" switch on the dash for those track days
The cracks were just in the rear wheels, could just make them out in the finish, sanded off the paint to find about 10 or so hairline cracks in one wheel and about 6 in the other.
The offsets of the forgelines never allowed me to run the tires I wanted, especially the rears, and now with the front brakes I need the wheel moved out about 5mm to clear, so I will have forgeline make new centers with some extra material on the hub mating surface so I don't need to use a spacer. Then change the rim outers to 1" so I keep the front offset manageable, will also move the inner barrel from the rear to the front to make the fronts 9" and redo the rears in a similar fashion, narrower outer by 1/2" and extra on the back space. Hopefully my calc's are correct and it will all work out nicely.
TIME TO ROAM----------
WINTER PROJECT=DRIVE THE CAR (Weather here in Scottsdale will be stellar for the next 5 months!)
60K service
footwell lighting
redye the seats/shifter boot
LED cabin, trunk, and engine lights
a good polish and wax
footwell lighting
I have Stoptech's on the car at the moment (will be for sale soon) for a number of reasons. The replacement parts are quite inexpensive, Can get slotted rotors for front and rear, they last about 3 times as long as the 993 RS brakes I had in the past, which last about 2 times longer than stock 993 brembo's.
And I don't need 380mm front rotors and 6 piston calipers, however they were at a price I couldnt pass up... And they will look awesome
- Rusty bumper brackets
That's all that comes to mind... I might kick around the idea of doing plugs/wires but I might want to save that for when the weather is a bit warmer!
