Does the 993 Carrera RS come in two Clubsport versions?
Hello
There is the base 993RS (little spoiler, no extravagant front lip) and the full on clubsport version wih front lip, removed carpets, big spoiler and cage. Is there one inbetween with lip + big spoiler but without cage that is still a clubsport?
Thanks.
Thanks.
M001 was the Cup option package no street use possible
M002 was the small wing RS package w/ carpets but otherwise stripped down, can be registered for street use most places(US is the biggest exception)
M003 was the RS/CS option package, no carpets, roll bar, different trans, suspension brace, buckets w/ 6pt belts, battery cut off switch, big wings, single mass flywheel
Some of the RS/CS options could be separately added to an M002 car
Bill,
FYI, all RSCS's that came to Australia did not have roll cages. They could not be road registered here with cages. Most of them then had cages installed if they were to be raced.
even if not that was a situation unique to Australia
if you don't want to believe me read through Porsche publication WKD 499 620
it clearly defines the items in option M002 and M003 for 993
The cages were not supplied with the M003 cars for Australia, the cars that went to compete in Porsche Cup ended up at places like Fitzgerald Racing services for cage installs.
I believe New Zealand and South Africa also received M003 cars without rollbars.
see above
RSR was an option package added to M001
M001 was an option pacage added to M003, this is called 911 Cup 3.8 and has M64.70 motor, G50/30 trans, n/b, 8.5 & 10 x18 center lock Speedlines 245/645 & 285/645 slicks, 72l gas tank, 4kg fire suppression
to that RSR added bolt on flares, dual fuel pumps, dual oil coolers, 100l gas tanl w/ bladder, the g50/34 trans got 8:32 cwp(g50/30 w/ 9:31 aslo optionally used), wheels were 9.5 & 11 x18(same tires as Cup), adjustable Bilstein shocks, all mono-ball suspension/steering
the M64/75 motor came in 3 versions all w/ ITB and resonance mintake(not the same as the street/Cup) manifold
62 P 85 701 - 715 w/ 40mm exhaust for ADAK-GT
62 P 85 716 -726 w/ 45mm exhaust & 48.2mm intake restrictor M64/80
62 P 85 727 - 730 w/ cat and mufflers
@Bill Verburg
https://www.hemmings.com/classifieds...3/2351752.html
What would this variant be considered (M001,M002,M003) ? I have tried to understand the three different variants but I am confused by what is what. Would love more information or thoughts. Thanks !
Apex-Monkey (07-26-2020)
That’s an M002 most likely from Japan where you were allowed to option it with things like the M003 club sport wing package but also add back in “comfort” options such as the sport seats, radio, airbags, power windows, etc. This makes the Japanese cars interesting, however personally I prefer the standard European builds due to their minimalist nature which aligns more to the purist RS ethos
for some reason you see a lot of these imported RS’s in the US in the Japanese spec
I think you were allowed to option the CS spoliler pack in Europe too so it's not particular to Japanese cars. This is a German origin car too so most likely delivered in Germany and then exported to Japan (assuming it's come from Japan) so technically not a Japanese spec car either.
Apex-Monkey (08-05-2020)
see above
A thing I was thinking of, being my intention to install the killer switch, is how they manage the headlamp leveling system, which was effectively eliminated with the clubsport version, having the red pull lever for the killswitch in place of the wheel for the leveling system (row version)
