993 Forum 1995-1998
White Smoke
Old 07-16-2016, 12:39 PM
dw.metro
dw.metro's Avatar
Default White Smoke
I took out my cat and replaced it with a straight pipe. This combined with the Fabspeed Maxflows makes my car sound come to life...truly exhilarating!
Only issue now is that I have white smoke coming out of my right exhaust. It doesn't happen at startup but it will happen after a restart when the engine is warm. The smoke lasts for a few minutes then it stops.
Any reason why this happens and could this be resolved?
Thank you.
Old 07-16-2016, 02:31 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
White smoke is generally fuel and you might check to see if one of your injectors is leaking. If they have never been professionally cleaned, this is something I'd strongly recommend.
Old 07-16-2016, 03:27 PM
jskylarwilson
jskylarwilson's Avatar
Steve, is it worth replacing the injectors, or is a cleaning just the same?
Old 07-16-2016, 05:34 PM
Sword_of_the_Spirit
Sword_of_the_Spirit's Avatar
A clean/flow-bench is usually all that's needed. If an oring is needed, the person to whom is doing the servicing can replace them no problem.
Old 07-17-2016, 11:21 AM
dw.metro
dw.metro's Avatar
Thanks Steve. As well, there is an black residue in my right exhaust pipe where the white smoke emits from which isn't present on the left exhaust pipe. Is this normal?
Old 07-17-2016, 05:13 PM
nine9six
nine9six's Avatar
Yes, and if an injector(s) is/are fubar, the same servicing facility will let you know what needs to be replaced.
Wipe your finger across the black residue; is it wet or dry, and does it smell heavily of unburned fuel, or is it oily?
Quick Reply: White Smoke
