In need of the forum's help assessing a new idea...
#76
It seems you've thought of everything! With every answer, they get better & better. I'm definitely in!
#77
Received 5,388 Likes
That's not the proper way to winter hibernate a Porsche. Never store with an unsprung suspension. Flat spot prevention is very easy. Just over inflate your tires to 58 psi.
#78
I think it's a great idea. I just spent $1,300 on a quick jack lift system to get basically the same benefits.
And I still don't totally trust it so I end up putting 4 jack stands under the platform for added safety.
The only additional benefit of the lift over your product is the ability to lift all 4 corners of the car simultaneously which was/is a concern for my F355. It seems those cars commonly suffer from cracking at the bases of the flying buttresses which is exacerbated by uneven lifting.
However yours has many additional benefits such as true portability, no need for power source, easier set up, more locking height positions and way cheaper cost.
I would definitely be a buyer at $150/pair $250-$275 for 4
I think you should reconsider the name to something with more universal appeal and that communicates the main benefit.
Rennjacks is too Porsche centric. You want to appeal a wider spectrum.
I happen to be in the automotive business and I think this product has commercial applications as well so keep that in mind.
I'd stay out of the Walmart's of the world because I think it would dilute the "professional grade" image you want.
Go through the more focused tool distributors.
I appreciate your thoughts on the pricepoint, as well as your insight into the name. I tend to agree with you that it will be lost on consumers outside Porsche circles. When I started out, my thought was to design stands primarily for our cars, and then shortly after having incorporated and trademarked I began to realize they had a much broader potential. I'll be considering more universal and descriptive options going forward.
Thank you also for letting me know you see their commercial potential! It's generally been off my radar as of late, though in hindsight the few professional mechanics I've let demo the stands in the past have expressed interest in purchasing them as a supplemental tool in their shop. You're right that I'd be remiss not to consider that market, and your opinion as an industry professional is greatly valued.
You got me thinking about Walmart too, and what effect it might have on the perception of the stands, and I think you made a very valid point. It is definitely important to me that these stands are seen as professional grade, which I believe they are, and I don't want to diminish that in any way. High quality tool distributors would be one great way to go if I can capture their interest ...
Very grateful for your thoughts and input!
#84
This is great! Since these are modular, it will provide all kinds of possibilities. I am interested for sure.
In terms of getting extra height, the extension can be made from the base dimensions. A straight middle insert with locking pins to connect the two pieces on the bottom together. Top of the middle piece would still accept the male insert from the top loop. Only concern for me would be the stability of legs now holding weight from a higher point.
We are all still going to keep pieces of 2X5 boards around to stack beneath the jack when raising and dropping the car though..
#85
#86
Curious as to why making these as "light" as possible seems to be a priority.
Personally, I could care less if they were made of lead, as long as it can easily hope the weight of my car. Its not like I would carry these in the car, garage use only for me.
#87
That said, the reason why I mentioned weight in my last response was because I wanted to be open with everyone on the forum that that figure is subject to change in the process of meeting other demands. If they end up heavier to maintain strength at increased height settings, so be it, but when all is said and done these are, and will remain, very strong stands for their intended purpose. Either way, assuming that your car is a 993 or of similar weight, the stands as is will more than hold the weight. Thanks again!
#88
I think the flexibility of multiple height options is important. People who want to buy extra parts to raise the jacks higher is another revenue source while keeping the current design height as an option as well.
#89
