UPGRADES?
FWIW ---- If you're satisfied with the performance of your car, esp with the supercharger, perhaps you may consider changing the ambience of the driving experience rather than addressing the driving experience itself?
Retrofitting the footwell lights, as banal as this sounds, was one of my favorite modifications. I appreciate that modification every time I get in my car in my garage --- even if I'm not driving it. The DIY instructions are in my signature.
I used a much thicker leather when recovering the shift **** and handbrake lever.
The first pic is of the stock C4S shift ****/boot.
I used to think the 3 spoke didn't quite work in the 993 but I then got a leather airbag for it and it makes it look a hell of a lot better. The 3 spoke does offer that little bit of extra leg space - not massive amounts like a small raid wheel does, but enough to make you want to stick with the 3 spoke over a 4 spoke if space is an issue.
I'd consider fitting a weighted shift **** as that does make the gear changes a lot nicer than with the light stock *****.
Indeed - I agree with this statement. I changed from a C2 shift **** (black plastic shift pattern, very light weight) to a C4S shift **** (heavy, weighted shift **** with metallic shift pattern) and it added a certain je ne sais quois to the gear change.
In all honestly, why would you be upgrading a car if you did not feel the difference after replacing suspension? I am being serious.
What are you after? Cosmetic changes? Than, what's the point of supercharger and suspension? What I'd recommend is a set of good tires and some autocrosses to understand what the car can and can not do. The rest kind of sounds superfluous. Of course, 996 steering wheel is both easy and useful as an upgrade. But, again, secondary.
List of upgrades depends on what you are not happy about in the car.
"Don't fix if it ain't broken". Spend the money on driving it - DE, car control clinic, maybe autocross.
