Speedline wheel Barrel size
I Am wanting to Build a set of RS Speedline wheels for a Widebody 993. The wheels FOR starting point would be the 8 x18ET52 AND 10 X18ET65 From the 993 Rs which are still available from Porsche. The information i am after is what the inner and outer barrel size is both back and front, Porsche did not Know. Trying to work out what i would need to buy to make A gt2 set up. Tim
You could try contacting Jim Dorociak (jdorociak@gmail.com). He could probably give you the specs and can probably sell you the parts you need or build the set for you. He is the speedline guru.
Tim-- Welcome; your 1st post on the 993 Forum! Great place full of helpful folks. As Jeremy recommended - Jim D. should have specifics on barrel sizes.
Once you get the barrel sizes you asked for: depending on Nick's details of completed wheels consider deferring those to me if you generously choose to
...Jim & other well-intended Rennlisters vectored me to Nurburger on the subject of procuring RS 993 Speedlines for WB fitment; contacted him via Private Message >1 year ago when Jim did not have all of the parts.
Nick-- At your discretion & Tim's concurrence:
Please "reply all" with wheels' & seller's details to the PM I just sent both of you
