If your car is a C4, the brake pressure warning light could indicate the brake pressure switch went bad. You'd know, because the system becomes depressurized and the brake pedal becomes very hard to push. Only the C4/C4S cars have this, not the normal C2. Mine gave up and I ended up replacing the pressure switch and the pressure accumulator.
