spark plugs
topic has been covered numerously... Please use the search function...
http://www.pcarworkshop.com/index.ph...1994_-_1998%29
http://www.pcarworkshop.com/index.ph...rk_Plug_Change
If they have been replace in the last 80k miles or so and you have no OBD Codes related to them I would not replace them. If you are having the valve covers off or the hydraulic lifter cartridges replaced I would add wires and plugs as it is just incremental work.
80,000 miles is too long in my opinion - you can have reduction of efficiency without triggering codes. My recommendation is 30-40 thousand miles, usually the plugs i pull at that mileage are starting to show electrode rounding and wear. Rotors/caps can go a bit further, again tempered by inspection. I do not replace plug wires based on mileage but on condition and external factors, like misfires. Wires usually shown heat induced hardening and cracking typically on the lower side of the engine, with wires for example on #6 lower taking a beating due to the tight corner the wires are routed near the plug.
I was reading all the various labels on my car. Amazing the fact I see them for 20 years of ownership and just discovering great content. Like emissions sticker showing vacuum routing and one of the stickers should have factory recommended plugs. Perhaps on door jam?
TJ, I'd just search for "spark plugs" and user name Steve Weiner-Rennsport Systems. The most definitive source we have here on all things 993 engine related.
Also info here:
http://pcarworkshop.com/index.php/99...rk_Plug_Change
Also info here:
bosch fr 5 Preferred ?
Thanks Keuth
Just confirming Bosch FR-5 is still Preferrred.>?
I pulled 5 - 11 - the plug I worry about most and she is a nice beige colour after 25000
Planning ahead and wanted to know if the Bosch is still preferred?
TJ
TJ
Also info here:
Also info here:
I'd give the Denso IK20TT a try. Had a good experience in another car & they'll probably outlast the engine. Happy w/ the IK20 in my 993, the TT version wasn't available at the time.
