rear tire wear and cupping...thoughts
Hey gang,
Have about 16k miles on this set of Sumitomo HTR Z3 rears.
Obviously I have a bit more negative camber than stock and also have a toe out of alignment, hence you get the cording on the inside with plenty of tread along the tread face.
What is new to me is the cupping on the inside. The drivers side doesn't have this.
Worn shock or control arm? I have a bad rear sway bar bushing, but the rest of the suspension looks pretty good from a visual inspection.
Any input would be superb. thanks
Received 5,388 Likes
Oliver, what tire pressures? Actually 16,000 miles on a rear set of tires for a 993 is not too bad. I could never get much over 12,000 on Kumhos and Yokos. IIRC, my passenger tire took more wear & tear than the drivers side.
This has been debated before, and I forget the consensus, but on low profile, boxy tires, tire pressures play an opposite relationship to PSI and cupping.
Does the passenger tire take more abuse because we drive +90% of the time without a passenger? The way the rear diff applies power to the rear wheels??
Ever thought about dismounting your tires 1/2 way through a life cycle, remounting and flipping sides to extend performance and tread depth a little longer?
37 might be 1-2 PSI low, but I know why you do it. Still, 16,000 miles is great, hard to complain.
Read this:
"Cups or scalloped dips appearing around the edge of the tread on one side or the other, almost always indicate worn (sometimes bent) suspension parts." I also found this problem is more prodounced with certain tire block designs and with harder tire compounds.
Had this happen on another car- my Acura- so not 993, but came down to an alignment issue and bent control arm. Replaced and the issue went away. The Alignment guys missed it too as it doesn't show up until the car is moving.
Seared
I had the same issue/wear pattern on 2 sets of tires on my 993 and my alignment was the problem. If you have an alignment with increased negative rear camber your total toe-in should be 0 to 1/8. If you do not have the toe-in equal on both rear tires you get cupping on the inside tread of the tire that is less toed in.
Also iirc, the kinematic toe corrects the toe out on outside and to toe in on the inside in a turn to staighten out the rear wheels. So if that is off, you can have too much toe-in turning one way but not the other. I must admit that the whole kinematic toe is beyond my alignment knowledge, but it does affect the toe and the wear if nit set properly.
Noodle Jr.
How often do people check their tires? I tend to give them a strong inspection every 2-3K miles by measuring tread depth across the tire (mm or 32) checking for cupping, separated belts, bubbles, punctures, and uneven tread wear in general.
