Rear blower doesn't come on after engine shutdown
Hi all, I've searched but I can't find anything that addresses my specific problem on Rennlist.
My rear blower doesn't come on when I shut the car down to cool off a hot engine. So far, I've confirmed that the rear blower works properly through the inside temperature and fan speed controls (i.e. low speed as well as high speed works as expected) so that rules out the blower relay and the low speed resistor as well as the CCU itself.
The only thing left (I think) is the temperature sensor in the blower. When I measure its resistance, it goes from 8K ohms cold to 2M ohms hot so it appears as if its reacting to heat. The interesting thing is that I disconnected the temperature sensor with the engine OFF and the fan came on so it looks like the CCU sensed "high" temperature and turned the fan on. Bad temperature sensor??
Does anyone know what resistance range it takes to "trip" the CCU to engage the blower? Any other ideas?
Thanks,
Ron
Thanks,
Ron
The Climate Control Module supervises the air duct temperature with a NTC thermistor. Normal value at 20degC is 12,5kOhm, and about 4.4kOhm at 45DegC. The measured value can be inspected wioth a OBD diagnostic tool connected to the CCU.
The CCU shall run the fan at low speed (40-45degC) and high(62-57degC) when ignition is ON and mixer valves are closed. (minimum heat setting) At igntion OFF, the fan run in low speed if the air duct temperature is above 75degC, and shall stop when below 70degC.
See my HVAC details page for further on this topic, Section Rear (AUX) Fan.
Cheers,
Tore
Cheers,
Tore
Thanks,
Ron
Thanks,
Ron
And, yes, pulling the sensor out will cause the fan to switch on - normal.
Tore: did you mean 4.4M Ohms hot? I measured about 2M Ohms on mine and Kurt confirmed that pulling the sensor out (i.e. creating an "infinity" resistance reading) turns the fan on.....so that would imply that resistance increases as the sensor heats up.
Thanks to all that replied.
Mine came on last night about 5 minutes after parking it and turning off the ignition and then stayed on for 10 minutes or so.
Normal operation?
Normal operation?
The rear air duct temp sensor is a 10k NTC thermistor, the resistance will decrease with increasing temperature. Measurements in the megaohm range indicates a defective resistor.
I guess the CCU have a failsafe mechanism that will start the rear fan if the sensor fails or is disconnected. It will also trip a fault code in the CCU. (15=Rear fan temperature sensor)
Cheers,
Tore
Cheers,
Tore
I don't have my engine tray on. I imagine if you did, that fan would come on a lot more. One thing I notice is if I leave the engine lid open it doesn't come on at all. Airflow is good!
The rear fan can run up to 20 minutes after ignition off. This is the same time as the CCU stays on.
Cheers, Tore
Cheers, Tore
