993 Forum 1995-1998
Wiring Diagram PDF
Old 06-20-2015, 02:18 PM
XavierLaFlamme
XavierLaFlamme's Avatar
Default Wiring Diagram PDF
Does any one have a PDF or link to the 993 wiring diagrams they would like to share with me?
Thanks,
Michael
Old 06-20-2015, 02:54 PM
bcameron59
bcameron59's Avatar
Check your PM
Jeriel (06-21-2020)
Old 06-20-2015, 03:04 PM
XavierLaFlamme
Originally Posted by bcameron59
Check your PM
Thanks a lot! I really appreciate it.
Michael
Old 07-13-2019, 10:49 AM
dacatz
dacatz's Avatar
Can I get a copy 2...thanks!
Old 07-13-2019, 01:38 PM
bcameron59
bcameron59's Avatar
See your pm
Old 07-14-2019, 05:34 AM
andyobro
2nd Gear
andyobro's Avatar
I would be very thankful for a copy to, been looking for one for a long time. Thanks Andy 👍
Old 07-21-2019, 02:37 AM
bcameron59
bcameron59's Avatar
How would i reach you? You do not seem to have Private Message set up on your account
cheers/bc
Old 07-21-2019, 10:57 AM
John Crisalli
John Crisalli's Avatar
If that link is still available, I'd like access to it as well.
JC
98C2S widebody
Old 07-21-2019, 03:00 PM
BobbyT
BobbyT's Avatar
When you get these files, they are really too small to read easily if you print them out on 8 1/2 X 11 paper. You can have them printed on 11 X 17 paper, a little heavier than bond. I uploaded mine to my local UPS store, and they had them done before I could drive down to fetch them, total cost about $3.
Now they are a useful size. Fold the 11 X 17 sheet in half, so it is 8 1/2 X 11. Then with the single edge at your right, fold the top part to your right, in half again, so the sheet makes something of a Z shape. Now you have diagram sheets that can be hole-punched, placed neatly in a ring binder along with 8 1/2 X 11 inch sheets, and easily pulled out flat for reading, just like the ones in the original shop manuals.
Old 08-01-2019, 11:46 AM
drola
drola's Avatar
could I get a copy as well?
Old 02-09-2020, 05:43 AM
Testastretta
Testastretta's Avatar
Hello, is it posible to get 993 year 1996 ignition wiring. I have no spark. I find 1995 wiring here on the forum but seems to me it does not match pin numbers on DME etc. From the car observation it seems to me the 1996 model do not have ignition module under the seat and the DME is connected directly to the coil in the angine area. Can you confirm?
Old 02-09-2020, 08:23 PM
bcameron59
bcameron59's Avatar
The DME relay is a common failure point, you might want to try replacing if you haven’t already. It is located in the fusebox in the front trunk.
The DME itself is under the driver’s seat in my 1996. If you remove the seat and the DME box isn’t there, the previous owner may have installed an aftermarket engine control system.
You mention something in the engine compartment that connects to the ignition coil, i’m don’t have access to my 993 just now so i can’t visualize what that might be - any chance you could post a photo of it here?
Old 02-09-2020, 08:50 PM
Foxman
Foxman's Avatar
Testastretta,
I’m sure BobbyT or someone can get you a wiring diagram. The 1995 model has OBD (on board diagnostic system) I, while later models have OBDII - so I suspect the wiring is slightly different. But all 993 models have the ECU (electronically control unit) located under the driver’s seat. The DME delay is located on the fuse box in the frunk. It sounds like you may have some aftermarket wiring...
As noted above, the DME Fuel pump relay is a common failure point. The engine will turn, but there’s no gas to ignite.
Old 02-10-2020, 01:59 AM
bcameron59
bcameron59's Avatar
Testastretta, you have PM
Old 02-10-2020, 09:49 AM
flashdavy
flashdavy's Avatar
hihi, can i get a copy of that wiring diagram as well?
I appreciate it very much!
Quick Reply: Wiring Diagram PDF
