Help! Rufus is powerless.
When lead acid batteries drop below a certain threshold they seldom come back to life. 0.02v is pretty darn dead. Its possible you got a bunk battery and it just died prematurely, it happens.
You can try to charge the battery but I doubt it will hold a charge under a load. The good news is it sounds like your battery is under a prorated warranty and replacing it will get you back on your feet (tires).
Agreed, you'd be better off swapping in a fresh battery and then dealing with the battery warranty at a later time when you're not in a rush.
ALSO TO CLARIFY THE DRIVE IS SATURDAY, NOT TOMORROW (FRIDAY)! Please, please, please don't show up at that Starbucks at 7:30 AM tomorrow wondering where the heck everyone else is!
They work well for 10+ jumps and also provide a power source for PC & cell phones.
http://www.frys.com/product/8330657?...H:MAIN_RSLT_PG
Good morning. I put the charger on at 2A all night. This morning the battery read 12.7V, but kept dropping as I held the voltmeter on it. I tried starting the car, and it started up OK. I called the battery shop, and realized the old battery is 37 months old... just outside of the free replacement zone. A pro-rated replacement will cost $117.00. I took the battery out and dropped it at Autozone for a check. They said that the battery tests ok, but only has 50% charge. Does that seem right with 2amp charge for 12 hours? They said they would charge it and retest the battery... come back in an hour. If the battery is indeed bad, I would probably get the replacement at Costco. Thoughts?
I strongly recommend getting a new battery. Bringing your battery "back from the dead" can be almost pointless, based on its performance/maintenance history. Charging and retesting the battery may provide false security as batteries can acquire a "surface charge" that may look good now, but fail again in the short term. Yeah, $117 is a bite in the pocketbook but at least you should be good again, unless there are underlying issues in the charging system.
It sounds like you're on the right track. Keep in mind you'll get a discounted battery price if you trade in your old one at the same time. (That or the posted prices assume you're trading in your old battery.) At least that was the case at AutoZone/O'reilly's iirc. I'm not certain how Costco handles these things.
On year three for my latest; the previous Interstate lasted 13 years!
Gordo
I think the Costco batteries are just rebranded Interstate batteries so they should be good.
Received 5,388 Likes
Any new battery. SearsDiehard. Walmart. AutoZone. Durlast. EverLast. Interstate MTP-91.
All fine.
Sent from my iPhone using Rennlist
All fine.
Thanks all. I decided not to take any chances with this 3-year-old battery that was suspect. I bught a new Interstate battery from Costco. In and running. Fingers crossed that the old battery was defective.
From what it sounds like, you should be good to go and ready for a great drive! Send pics!
RP
