Fog light / backup light circuit
2nd Gear
So just finished my first oil change and brake flush on a 993 in prep for winter storage. Thanks to all you diy'ers who take the time to post tips and procedures. I thought all went well until I discovered that fuse 14 on the backup light circuit blows each time I shift into reverse.
Hoping that someone here might have a theory about some wire I might have damaged during the course of this work. I believe it was working fine until the oil change so best theory is it was related to mucking about under the car somewhere.
Cheers
Cheers
2nd Gear
Led bulb was the problem
So after chasing around to every thing but the led bulb in my reverse lights with the multi meter I discovered there was a dead short in one of the bulbs! Problem solved.
