993 Forum 1995-1998
Remove brake line from caliper for rebuild?
Old 11-05-2015, 03:54 PM
_snowbird_
_snowbird_'s Avatar
On the topic of rebuilding, I was reading some threads from 2-3yrs ago about the OEM Brembo piston and seal kits. Most said the 16 kits came to about $300. Looking at pricing now, it's nearly double.
Any leads on affordable OEM kits?
Old 11-05-2015, 09:06 PM
AOW162435
Seared
AOW162435's Avatar
I think the 16 Brembo kits from Sunset were somewhere around $300 when I rebuilt my calipers four years ago. I initially purchased the wiper seal & dust seal kits from Zeckhausen but returned them since the dust seals seemed very, very flimsy.
In the end, the complete & proper Brembo kits (pistons/wiper seals/dust seals/lube) were only $100 more than the aftermarket seals...
Andreas
Old 11-05-2015, 09:42 PM
_snowbird_
_snowbird_'s Avatar
Andreas
Yes - I've been reading your threads for guidance I just priced the kits out at Sunset and Suncoast, and both are just shy of $600 now!
Old 11-06-2015, 10:28 AM
NYC993
NYC993's Avatar
Not cheaper, but they have an option without pistons which is significantly cheaper:
http://www.racingbrake.com/category-s/7185.htm
Old 11-06-2015, 05:35 PM
Chris V
Chris V's Avatar
$56 for boots and seals per caliper vs $316 for pistons, boots and seals for 2 calipers...yes, significant difference
How often are new pistons actually necessary? Aside from visible corrosion, what are the signs/symptoms that pistons should be replaced?
Old 11-06-2015, 05:57 PM
NYC993
NYC993's Avatar
I'm planning to replace just the dust boots, some of which are torn and leave it alone.
Chris V (03-12-2023)
Old 11-06-2015, 09:29 PM
_snowbird_
_snowbird_'s Avatar
Good find! Now we're getting somewhere I also see that Paragon sells some sizes of individual pistons for $5-8ea.
http://www.paragon-products.com/Brem...-kits-late.htm
But as Chris V mentioned, I'm curious to know how to diagnose a need for piston replacement?
Old 11-06-2015, 09:39 PM
AOW162435
Seared
AOW162435's Avatar
The original Brembo pistons are anodized aluminum. All 16 of mine looked utterly perfect. Since I purchased the complete rebuild kits, I installed the new pistons and sold my originals.
If the pistons show corrosion or scoring, they're obviously in need of replacement. But that would possibly point to other issues...
Andreas
Old 11-06-2015, 10:22 PM
_snowbird_
_snowbird_'s Avatar
Andreas
Thanks Andreas. That's helpful.
Quick Reply: Remove brake line from caliper for rebuild?
