How to fit 993 front bumper to wing (fender) seals
Perfect timing! Thanks. Ill be doing this next week. I still don't understand Mikes comment "I usually have to pull the center top of the cover up to take away some width to place the bumper between the metal fenders. " but Im sure it will be obvious when I get to it.
Translation: You might have to flex up the centre of the bumper to narrow the width of it slightly to ease the fitting between the nose sections of the front fenders. It's a snug fit. Unfortunately I missed photographing the fit of the bumper as I was tied up dealing with a customer.
great write up and pics on that. Loved it. Took me two tries to get it right. I had the glue come off when sliding the bumper into its location. The rubber held best with staples, tucking all the staple ends in was a must.
great job and thanks for posting this
It's interesting to see how the ledge wall where the seal nests varies in height getting taller as it curves up towards the hood. That obviously causes the finished seal to appear 'deeper' into the gap from the headlight inboard and I think a lot of people fight that ...
that is the most over thought process I have seen in my life. no wonder they are not perfectly fit around the bumper. I would have thought an aftermarket company would have came up with a custom shape rubber molding that would just encapsulate the bumper inner lip and forgo all the hand settings (human error) and staples. That is awesome to see how its done and such a technical application for something simple like a front bumper. thanks for the insights.
(+Thanks to Colin for detailing such a finicky DIY. )
^^^ It's the way it's designed. If you look at cars that still have their original, unaltered factory installed bumpers and seals, they look the same.
Colin thank you so much for contributing to this board as much as you do and posting up this thread at my request. I for one appreciate the time you have put into doing this
Below is pictures of my job following a full respray. We live in a small town community and so the painters who did a great job did their best to get everything right as we all know each other and look after each other.
They had two attempts and several hours at positioning the bumper rubber and the pics below are the end result. Rather than have them try more I thought it best to see if they were just going about it the wrong way. So your thread is invaluable. Like most people they have simply used an adhesive only.
I'm going to do the job myself and see if I can get a better result. The worst area is where the rubber terminates at the corner of the bonnet where there simply doesn't seem enough room or "width" for the rubber itself.
The other issue was the sunroof felt which now sits proud and had excess adhesive visible. Those that have priced this felt up will know that its not cheap so I'm hoping that I can use a adhesive remover and clean it off the felt when I remove it from the sunroof to refit. Will removal and refit even be possible?
Thought I should post up the overall finished result.
Mods done while at the painters.
1) Removed headlight washers nozzles.
2) Installed brake cooling ducts, ducting and new side lights.
3) Removed rear basket handle.
4) Removed all US bumperettes and filled bumpers.
I also replaced all rubbers, gaskets, badges etc. All parts supplied by Darin @ http://fdmotorsports.net/ who was great to deal with as usual (No affiliation etc etc).
You should be able to re-use the sunroof seal Kiwi provided that you take it off carefully. The secret with the front seal of the sunroof is that the top of the radius of the seal should be flush with the outer face of the roof, which means that you should apply adhesive to the flat section of the seal only, apply masking tape 2-3mm down from the roof face, then apply adhesive below that. The rear seal on the sunroof itself fits in a similar manner.
We have found that some of the new sunroof seals are coming in with a fractionally thicker profile than the original seals that can cause problems with the closure of the roof. The symptom is that the roof will stop short of fully closed unless you apply a little upward pressure from below. The remedy here is to either re-use an old seal if it is good enough or somehow flatten the new seal slightly before it is applied.
If I remember, the next time we fit a sunroof I will post another how-to thread since this and the bumper seals are the two tiny details that let can down a lot of rebuilt or repainted 993s.
