Go Back  Rennlist - Porsche Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 993 Forum
Reload this Page >
Increase 993 chassis stability and enhance shifter feel and accuracy
Old 12-24-2013, 11:36 AM
  #61
Function-First
Basic Sponsor
Function-First's Avatar
This can be installed with the trans in the car on the 2WD models. By removing the cross member under the transmission, you should be able to nose down the trans housing enough to pull the trans carrier mount bolt out at an angle. This will free up the trans carrier, allowing access to the bushing from both sides. Upon reassembly, slide the bolt into the bushing from the opposite side, as there is sufficient clearance from this side.
Please let me know if I can help with anything else. You can contact me directly at [email protected]
Function-First is offline
Old 12-24-2013, 11:47 AM
  #62
jstyer
jstyer's Avatar
Luka, email sent.
jstyer is offline
Old 12-24-2013, 12:31 PM
  #63
Ed Hughes
Ed Hughes's Avatar
Interesting comment on 2wd. We fought that bolt when dropping my motor a few weeks ago. Got it out after a wrestling match.
Ed Hughes is offline
Old 12-24-2013, 01:05 PM
  #64
Function-First
Basic Sponsor
Yes, another member here was also able to remove that bolt with the trans in the car as well. It is a tight fit, and care needs to be taken, but it's definitely possible. And it definitely beats having to drop the transmission!
https://rennlist.com/forums/9114952-post8.html
Old 12-24-2013, 01:39 PM
  #65
Vandit
Super User
I think this is going to be dictated by the motor mounts you're running. I can see standard motor mounts yielding enough to drop the trans nose far enough. I can see Wevo mounts struggling at having enough yield to pull this off. There just isn't much bushing material to flex. You don't want to force / bend the the inherently weak carrier.
Vandit is offline
Old 12-24-2013, 04:07 PM
  #66
Function-First
Basic Sponsor
Obviously this is to be tried at your own risk, as I have not installed the Inserts on a semi-solid equipped 2WD 964/993 so am unable to confirm this, but perhaps the semi-solid engine mounts can be loosened slightly (at the studs) to allow for more play btwn the mount studs and carrier.
Old 12-29-2013, 01:19 PM
  #67
Quadcammer
Super User
ok kids, I spent some more time with the car this saturday.
bottom line, if one only knew a 911 from stories, they would get in a car with this tranny insert, wevo motor mounts, and a golden rod and go..."yup, this is how a 911 should shift".
It just feels crisp with very little slop. how it should be.
My recommendations:
1. wevos or rs mounts...just do them
2. golden rod
3. tranny insert
4. short shifter (optional)
really changes the car for less than $650
Quadcammer is offline
Old 12-29-2013, 03:19 PM
  #68
Todynot
Todynot's Avatar
Quad, can all those be done to normally aspirated NB 993? I ask b/c don't you have a turbo model?
Todynot is offline
Old 12-29-2013, 03:35 PM
  #69
Quadcammer
Super User
yes, all these can be done on an NA. There is a slight concern over engine carrier weakness with wevos, but I think if you go with the softer black pillows, you'll likely be fine.
Old 12-30-2013, 10:53 AM
  #70
MielsOnWheels
MielsOnWheels's Avatar
My recommendations:
2. golden rod
3. tranny insert
I've done 3 of 4 of these so I guess I'm on the right track!
Not being the mechanical type, do we have a ballpark cost on how much an Indy would charge to install this? I've got WEVO Blacks so would they likely need to drop the trans nose or given their skills/tools be less likely to need to do that?
Sorry for the silly questions, but I'm intrigued by this product given the improvements I've seen with the other 3 upgrades....
MielsOnWheels is offline
Old 12-30-2013, 11:03 AM
  #71
Quadcammer
Super User
not sure on the NA cars, but I can't imagine it would take a skilled indy more than 2 or 3 hours to do this. It stings a bit if its not DIY-able for the average person.
Old 12-31-2013, 03:44 PM
  #72
OverBoosted28
OverBoosted28's Avatar
I know this product is quality but at $130 bucks it's a bit much. For about $30 bucks I got liquid urethane and poured my ownName:  image.jpg
OverBoosted28 is offline
Old 12-31-2013, 03:57 PM
  #73
Busta Rib
User
Busta Rib's Avatar
Originally Posted by OverBoosted28 View Post
I know this product is quality but at $130 bucks it's a bit much. For about $30 bucks I got liquid urethane and poured my ownAttachment 792361
That's one way to do it. Clever. Only downside is it is not reversible, but most people probably wouldn't care or notice.
Busta Rib is offline
Old 12-31-2013, 04:12 PM
  #74
Function-First
Basic Sponsor
Filling your transmission mount with liquid urethane, or similar, will stiffen your mount, but there are several drawbacks to that approach:
1. It lacks the sidewalls inherent to the Trans Mount Insert design, so it won't effectively limit lateral engine/trans movement
2. It takes several days to fully cure
3. Chances are, the urethane won't be the proper hardness rating
4. It is permanent, so if you want to return your car to stock form (to sell it, for example), it will cost you over $200 to purchase a new transmission mount
Old 12-31-2013, 05:09 PM
  #75
OverBoosted28
I understand it's not reversible, but I'm NEVER selling the car :-) Here's a pic with in the mount.Name:  Tranny mount w spacers.jpg
It's 94A hardness
Quick Reply: Increase 993 chassis stability and enhance shifter feel and accuracy
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
