Go Back  Rennlist - Porsche Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 993 Forum
Reload this Page >
Increase 993 chassis stability and enhance shifter feel and accuracy
Old 12-07-2013, 10:55 PM
  #31
Quadcammer
Super User
Originally Posted by e9stibi View Post
Is there a posting with pics? I am a "visual" guy?
Originally Posted by Function-First View Post
Locate the big crossmember as shown above.
See mount with big horizontal bolt. Remove bolt
Easier than my above instructions:
On the crossmember, there are 6 vertical bolts. Remove.
Add insert. Slide crossmember up, put bolt through the mount and lightly tighten.
lightly tighten 6 crossmember bolts.
torque all to spec.
This is very very simple on the awd cars.
Quadcammer is offline
Old 12-08-2013, 03:50 AM
  #32
CalvinC4S
Super User
CalvinC4S's Avatar
^Just make sure not to be under your car if you do it this way
Insert jack between step 1 and 2.
CalvinC4S is offline
Old 12-08-2013, 08:18 AM
  #33
Magdaddy
Magdaddy's Avatar
Originally Posted by NC TRACKRAT View Post
Feedback/Review from anyone who's installed these inserts?
also awaiting this...
Might be another to-do item during my cars long winter hibernation.
Magdaddy is offline
Old 12-08-2013, 11:34 AM
  #34
Quadcammer
Super User
figured that went without saying, but solid point.
I"m ordering today and will post my reviews.
Old 12-08-2013, 01:30 PM
  #35
sfbluenote
User
sfbluenote's Avatar
Quadcammer…Im looking forward to your review.
sfbluenote is offline
Old 12-08-2013, 02:22 PM
  #36
pcarrera993
pcarrera993's Avatar
+1
Hope it's as good as it sounds.
pcarrera993 is offline
Old 12-08-2013, 02:51 PM
  #37
phoneyman
phoneyman's Avatar
I'm waiting to here about this product like everyone else. Heres my official subscription
phoneyman is offline
Old 12-08-2013, 07:25 PM
  #38
mr_bock
User
mr_bock's Avatar
I have a 911 993 C2... I went with the what looks like nylon solid insert. No issues (just had to file a small relief to accommodate the aluminum casting) feels tight. My Light Weight Flywheel does transmit some gear clash noise when in neutral, but that's Ok.
mr_bock is offline
Old 12-13-2013, 05:07 PM
  #39
Quadcammer
Super User
Ok gang, just installed this thing.
Very straightforward:
1. lift car, remove tranny tray (3 screws per side, 2 10mm plastic nuts per side), use a small jack to support transmission
2. loosen center bolt (17mm bolt/nut) but leave in.
3. remove 6 17mm bolts on tranny crossmember
4. Remove center bolt and remove c-member
5. Remove 3 15mm nuts from mount and slide mount off tranny (awd)
6. Slide insert into mount. Mine went in with no force or lubrication.
7. Reinstall mount.
NOTE: WHEN PUTTING THE MOUNT BACK ON THE TRANNY, THERE WAS INTERFERENCE BETWEEN THE INSERT AND A RIB ON THE TRANNY. I NEEDED TO PUT IN A V-SHAPED SLOT.
8. With slot cut, install mount, tighten 3 nuts. Torque to spec.
9. Position crossmember and slide center bolt through mount/cmember. Then rotate cmember up into position. put nut back on center bolt but leave loose.
10. reinstall 6 c-member mounting bolts...torque to spec
11. tighten center bolt, torque to spec.
12. reinstall tray.
13. lower car, done.
I used 50nm for all bolts.
I have not driven the car yet, but will do so later this afternoon.
Here are some pics:
Crap picture, but here is the interference:
Here is the v-slot to clear rib:
Installed:
Old 12-13-2013, 05:25 PM
  #40
ilko
Agent Orange
ilko's Avatar
Crappy pics indeed, you need an iPhone
ilko is offline
Old 12-13-2013, 07:15 PM
  #41
Quadcammer
Super User
lets just say the device is not the problem. I can't take pics to save my life.
Old 12-13-2013, 11:32 PM
  #42
Quadcammer
Super User
Ok driving impressions:
Now I didn't go out and beat the nuts off of it cause of the temp and salting, but the car shifts very nicely. The shifting seems more precise and direct, but it will take more driving to be sure.
No noticeable additional NVH.
Based on my car, which has wevo mounts, golden rod, and short shifter, its a nice difference but it is not life altering. Its a pretty subtle effect, albeit a positive one.
Really want to get more time with it before deciding on the extent to its effect, but i've certainly spent $130 on worse things.
My opinion, give it a shot, I noticed no real downside.
Old 12-14-2013, 12:33 AM
  #43
pcarrera993
No NVH is a positive. Thanks for feedback.
Old 12-14-2013, 10:28 AM
  #44
Quadcammer
Super User
yeah both myself and embpilot couldn't really notice any additional noise or vibration. If its there, its incredibly minor.
not sure if this is different for the rwd cars.
Old 12-14-2013, 08:13 PM
  #45
Function-First
Basic Sponsor
Function-First's Avatar
In regards to the interference with the transmission housing, I have updated the design of the Inserts for the AWD models. I will incorporate this change going forward so that the Insert is truly "plug and play."
A big thanks to Quadcammer for bringing this to my attention and taking the pictures to help remedy this issue!
For those that have already ordered their Inserts, I apologize in advance. You can (carefully) use a razor blade to cut and remove the unneeded material that is interfering with the trans housing - please refer to the pictures of the updated design below. Removing this material will in no way inhibit the effectiveness or durability of the Inserts.
Function-First is offline
Quick Reply: Increase 993 chassis stability and enhance shifter feel and accuracy
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
