What is this and is it a DIY?
Saw this tonight when i got home when i was checking my oil. Not sure when it ripped but havent noticed any effect on the performance. Seems to surround the fan housing but thats where my guessing ends
Is this part easily repairable? Any ideas on costs if its not a moderate diy? I can undertake relatively minor stuff but if it is too involved it will have to go to my indy
Any harm in driving it in the meantime?
Any thoughts appreciated
vern good sir, this has been discussed nearly one billion times.
a simple search will reveal all.
the short:
simple to replace, 3 10mm bolts, part costs about $45
the short:
Quad good sir if i knew what to search for then i would have definitely done so. Just no idea what to look under. Pls fill me in and i will do so and thanks for the direction
Date: Mon, Sep 23, 2013 at 12:50 PM
Subject: RE: part
To: Mark Harris
Hi Mark
Fan $408.40 9641060153
Cover $32.83 99310640300
Sensor $86.66 99310603500
Quote #121157
Plus shipping to you
We have all in stock at this time
Thank you!
Bob McCarthy
Sunset Porsche Parts
Toll Free: 800.346.0182
Direct: 503.726.2257
BobMcCarthy@sunsetimports.com
DIY?
only if you can;
I suspect it is well within your capabilities
have fun and good luck
only if you can;
- order the part
- receive the part
- remove the defective part,
- 8mm socket
- 2" extension
- ratchet
- Install the new part
- align the components
- drink beer afterwards
Seriously, I thought someone had vandalized my car when I saw that on mine. I looked up the part using the Porsche parts manual - you should get the one for your car:
https://rennlist.com/forums/993-foru...-for-free.html
Then I did a search here on the part name and discovered it's a common failure but not expensive or time consuming.
I taped mine up with electrical tape for fear or impacting cooling airflow until the new part arrived.
