Introduction - New NB Aventurine 993 owner & and tire fitment question
#31
Thanks all.
Given that it is a narrow body car, I'm baffled as to why the previous owner put on Mich Super Sport
205/40/18 fronts and 255/35/18 rears! I just realized the rears have sizing issue too! And its such a shame --- the tires all still have the "molding nubs" on there.
Anyways, Porsche recommended tires are 225/40/18 fronts and 265/35/18 rears.
The excessive "stretch" of the tires on the wheels bug me....I suspect the previous owner (young guy) liked the "look" of of the stretched tire.
The Bridgestone S-04 tire ends up being $150 a set cheaper than Michelin Super Sports and I do 100% street driving --- and fairly relaxed driving at that. I'd be tempted to put on another set of Michelin Super Sports but the fact that the rear wheels are 18x10 +55 (whereas OE is +65) make me a little nervous to put on Super Sports in 265/35/18 in the rear because I hear that the S-04s are slightly narrower that Super Sports.
#32
Hi Mike -- you are running 285/30/18 on a NB in the rears?
Are they still Pzeros? What is the offset of your 18" speedlines in the rear?
#33
My previous tires were Pzero's and my new tires are Sumi's and they are both 285's. My rear wheels are 65 offset. No problems with either tires rubbing.
#34
#37
Hi folks ---- thanks to all for your helpful comments and suggestions!
I bought Bridgestone 225/40/18 and 265/35/18 tires and had them mounted on the car. I think I would have preferred Michelin Super Sports but I couldn't pass up the $300 delta @ TireRack between the two.
Mounted the tires on the car and it looks much better --- much more correct and not nearly as strange with the older narrower F-205 and R-255 tires being stretched on the wheels.
BTW --- this is with 18x10 ET+55 wheels in the rear on an M030 suspension on a Narrow Body 993. Since Bridgestone 265/35/18 S04s fit this way, it suggests that 18x10 ET+65 (orig Porsche fitment) with 285 section Bridgestone S04 tires in the rear on an M030 suspension might fit as well...
Rear Tire:
Front Tire:
Front Tire Again:
Rear Tire:
Front Tire:
Front Tire Again:
#38
Porsche factory tires/wheels bulletin
Jim,
Here's a link to the Porsche factory tires/wheels bulletin:
https://rennlist.com/forums/attachme...-summary-1.pdf
