Stock vs Elephant Racing Bushings
Have you priced the components from Porsche? The Elephant Racing bushings will look like a bargain compared to new front control arms. The ER bushings are made by the company who makes them for Porsche.
One thing I could never figure out is why a company like Porsche who is out to make a profit like any company, would not go with cheaper PU bushings. Actually, why doesn't any manufacturer?
Have you priced the components from Porsche? The Elephant Racing bushings will look like a bargain. They are made by the company who makes them for Porsche.
My thought FWIW, would be Walrod's in front, new lower RS wishbone for a fresh start on forward bearing and ball joint as well as RS rubber, and Elephant RS rubber bearings in the rest of the rear arms.
Then put these in the Subframe http://www.fvd.de/us/en/Porsche-0/99..._85_Shore.html
Having said the above, I had questions about the Elephant bushings because I noted 2 different styles of bushing in my rear suspension, a thin and a thick rubber annulus bearing. I don't recall which went where (maybe someone can look at their car?) , but think the thin bearings were in the rear toe arm.
So, not being sure what bearings were "really" in an RS, I eventually went metal bearings and solid subframe mounts in the rear.
Below a new Elephant on the left, stock bearings center and right, note the Elephant only matches that in the center:
EDIT: I just checked a track control arm I have and it has the style of bearing like the Elephant and Center pictured. The one on the right goes in the toe arm, which makes sense since the pivoting of the track arm against the toe arm creates the passive 4 wheel steering that Porsche was trying for.
Basically, this steering effect is eliminated by using solid metal bearings as was done in the race cars.
A stock bushing on the top and an Elephant Racing bushing on the bottom.
-PSS10's at ROW height
-Walrod PU bushes in the front
-Check rears and leave if they are ok, get new arms if they are not
-more neg camber as allowed by oem plates
-maybe new engine mounts
-alignment and corner balancing
With these changes, go to track and assimilate, from there add further enhancements as needed that way i will try to gage improvement bit by bit...
rubber for street
monoball for track
w/ some overlap
It never fails to amaze me how people spend lots for the car than cheap out on parts
Why would you use p/u in front and rubber in the back?? that doesn't make sense, use rubber or monoballs all around.
Solid sides make a huge difference for track and very low cars, not so much for most 993 owners
RS only used harder bushes on the trailing fronts, trailing ream A-arm and and the rear kinematic arm, all the others were the same as on other 993s
Chris Walrod's bushings have been a fairly simple and effective way for many here to refresh control arm bushings that have more than a few years and miles on them, in their own home. They are the pick up points that seem to show the wear the most. I think the cheap as * method is to think one doesn't need new bushings up front, and keep the originals in place.
Because they are a cheap as* shadetree solution and inappropriate for the application
rubber for street
monoball for track
w/ some overlap
Maybe for me, since it's a street car mostly that will see occasional track use the walrod is a better deal?
