WTB: set of 20 steel lug nuts (Porsche/Rennline/RAD/etc.)
08-04-2013, 12:50 PM
SearedRennlist Member
If you have a set that's collecting dust, or has minimal use, please let me know.
Andreas
08-04-2013, 01:09 PM
Which type seat do you need? I have a set that is new from rennline.
08-04-2013, 01:21 PM
Ball seat. PM sent.
Andreas
08-04-2013, 01:26 PM
08-04-2013, 06:01 PM
Noodle Jr.Rennlist Member
He is replacing the screws loose in his big head.
08-04-2013, 07:21 PM
Quote:
Originally Posted by
Cactus
but...he only needs two of those nuts to tighten the bolts protruding from his neck?
villagers with pitch forks bad
cheap nuts...good
08-04-2013, 07:51 PM
any consensus on which is the best solution?
08-04-2013, 08:02 PM
Depends on what you're trying to solve.
20 steel nuts, fastened to spec by hand with a torque wrench, wheels roll.
08-04-2013, 08:33 PM
Matt Lane
just looking for the best quality and trying to avoid trial and error. would hate to have faulty nuts ;-)
08-04-2013, 08:58 PM
Just pulling your leg!
I bought my spare set from Pelican. I think they are actually a VW part number, but not sure. In any case, not much to go wrong with steel.
Cheers
Matt
08-04-2013, 09:41 PM
RL Technical Advisor
Magdaddy
cheap nuts...good
Please,..pleasure warn me with this stuff. I laughed so hard that almost fell outa my chair (even with 6pt harnesses).
I have an image of Andreas now burned into my head (needing nuts).
You people are too much,...
08-04-2013, 10:06 PM
Nut search over. Thanks Jim.
Andreas
08-04-2013, 10:25 PM
08-04-2013, 11:17 PM
08-04-2013, 11:48 PM
AOW162435
Andreas
Hang on hang on hang on...........why did Jim have your nuts?
