Project Lightweight
#34
Jordan, that's good to hear.
The weight loss is actually really beneficial, it can be felt in every turn. I've been starving my autocross appliance, it's down to about 2,070 lbs. Need to get rid of another 100 or so, not sure where yet.
#35
King of Cool
That's a good one I don't really need it in my parts so I don't mind not having it in the 993 but I would not remove it from my GT3
#37
Given the choice between adding horsepower or its equivalent as weight loss, I will take weight loss every time.
For example if a stock 993 with driver weighs 3250 pounds and has 286 HP then weight to horsepower = 3250/286 = 11.36 : 1.
If we add 50 HP it becomes 3250/336 = 9.67
If we decrease weight by an equivalent = (9.67/11.36) X 3250 = 2766 pounds target weight.
3250 actual - 2766 target = 484 pounds required reduction.
So losing 484 pounds in this example is = 50 HP as far as acceleration is concerned, however every other performance criterion will improve as well: cornering, braking and steering response. The lighter car will be faster around a track.
The car will be easier on brakes and tires and there is no downside other than increased NVH.
#41
If one removes the HVAC completely and uses lighter exhaust header plus removes the bumper beams 500 pounds reduction is in sight.
The 484 pounds was derived from picking 50 horsepower as a nice round number and working from there.
Removing 400 pounds is roughly the equivalent of 40 added horsepower in a 993.
#42
I'm at 9.11 lbs/hp, very streetably, I could easily drive to the track or anyplace else if wanted to waste the tires,
honestly, the big 3 in order are weight, gearing and them hp/torque
#43
There's also a question of what's "streetable". I can drive my appliance to the events, but would not want to drive it around town much (it's loud, it's hot, it's hard to get in and out of, it has no radio, it's stiff as a brick, it's dangerous in the wet, it doesn't start well, etc). But, hey, it lost about 15% of its initial weight.
#45
Good discussion!
I've been thinking about unsprung mass as the biggest potential bang-for-the-buck modification for my car for the same reasons discussed here. I suspect that unsprung mass savings improve NVH, can't prove it yet.
Just put new rubber on and was impressed by 31lb rims with 28lb rubber. New rotors must have been another 20lbs. There must be close to 100lbs on each corner.
Saw an article on some kevlar/carbon fiber wheels that had same strength for 10lb savings. There must be NASA technology for light weight rotors? I don't see any of this available yet. Is it the safety approvals process?
