9m 993RS hollow anti-roll bars - Rennlist exclusive group buy offer
Great idea, couple of questions though:
1) what's the OD of the front bar, have you confirmed clearance to vacuum booster on non-M220 cars?
2) have you considered increasing the-neutral setting stiffness to the equivalent 24mm F / 21mm R? Asking because I have yet to see anyone use the soft setting & don't expect to as tires continue to improve.
Colin,
My RS bars have all sorts of kinks and bends. I assume these are necessary. How do you plan on bending the tubular bars to this shape without altering the diameter at the bends? If you go with straight hollow bars of a larger diameter, surely you will have all sorts of interference issues. Wouldn't you get a more predictable and reliable solution if you made a slightly thicker copy of the RS bars out of solid material?
John
John
