993 Forum 1995-1998
Recommendations regarding a half-/roll-cage in a 993?
Old 05-07-2013, 04:53 PM
  #46
oysteinw
oysteinw's Avatar
Originally Posted by nurburgsingh
I was suggesting that if you're going down that route that a full cage is what you should be considering...
I must admit that a full cage feels a bit "over the top" for my use, with about 60% track and 40% street...but of course; if it's all about safety you're quite right - a full cage would definately provide the best protection.
Regards,
Oystein
Old 05-08-2013, 02:04 AM
  #47
Holger3.2
Holger3.2's Avatar
As usual, there a best and second best options ...
1. full cage - definitely for racing / not practical for road use
2. roll-bar - should be good for track days + road
3. none - still ok on the road ...
main difference between race and track day is that there should be no chance of contact, which accelerates the chance of flipping
therefore, the commonly selected second best choice (roll-bar) should be more than sufficient ...
IMHO (with the 2 cent value)
Old 05-08-2013, 03:35 AM
  #48
oysteinw
oysteinw's Avatar
Heigo roll-cage with harness bar is hereby ordered.
Regards,
Oystein
Old 05-08-2013, 02:47 PM
  #49
clib
clib's Avatar
Considering a similar set up.
For those who have already installed the Heigo roll bar, can you outline what is involved in installation? I see its referred to as bolt-in but are there welding for mounting points needed to install. Any other things to prepare for?
thanks
Old 05-08-2013, 03:10 PM
  #50
Cupcar
Cupcar's Avatar
thanks
Looking at the pictures, it appears to me that the roll bars bolt in with 4 bolts using the lateral front and rear lap belt mounting bolts.
I wonder how many rule books allow only that.
Also it seems to me that a bar designed for the RS carpet set could easily have an aft going brace go to the rear shoulder belt bolts rather than just lap belt bolts for a total of 6 bolts.
Old 05-08-2013, 06:22 PM
  #51
Macca
Macca's Avatar
8 points. B pillar lower and upper OEM seat belt bolts (2 each side = 4). Rear seat-belt receptical and mounting points 2 each side = 4). All mounting points are factory seat belt points so very secure...
Old 05-08-2013, 07:22 PM
  #52
clib
clib's Avatar
thank you. And you can retain the OEM seatbelts for street use as well?
Old 05-08-2013, 07:41 PM
  #53
race911
race911's Avatar
None that I know of in the US. Then again, most DEs over here are self-tech, and 75% of the time I opt for factory belts when riding in a car that's had additional "safety" equipment installed. When the factory three-point has been altered, I'll decline unless we're in the lowest of the low beginner groups.
Old 05-08-2013, 07:52 PM
  #54
Macca
Macca's Avatar
Yes the OEM front belts have their full functionality...
Old 05-09-2013, 01:55 AM
  #55
Holger3.2
Holger3.2's Avatar
I think its 6 points only... B pillar lower OEM seat belt bolt only ...
I wish they would have one more bar to the upper rear seat belt point, but ....
At least, heigo bars are some of the few which are (technical) approved by German TUV, for legal necessary registration for street use (in Germany).
Holger
Old 05-09-2013, 02:12 AM
  #56
Macca
Macca's Avatar
Damn I cant count! You are right i was including front seat belt anchor! Anyway ist 6 which iss more than 4..
Old 07-14-2013, 01:23 PM
  #57
Holger3.2
Holger3.2's Avatar
Hi Oystein
send you a PM re some actual trouble with Heigo deliveries ...
Holger
Old 07-15-2013, 06:48 AM
  #58
oysteinw
oysteinw's Avatar
Default Update
Hi,
The last post from Holger3.2 reminded me about updating this thread (sorry about that). I ordered the Heigo roll-cage via my local Porsche-dealer, thought that would be a good idea in case of delivery problems etc. (just let the guys at the Porsche center deal with it). They warned me about the delivery time and estimated 1-2 months. About 6 weeks after my order the roll-cage was ready for pick-up at the Porsche center, and a couple of weeks ago I installed it in my 993. The install was a bit more tricky than I thought it would be, but no actual problems really...just needed a dose of elbow grease since I was doing this all alone (think it would have been easier with a helping hand). Will post some photos later.
Old 07-15-2013, 07:01 AM
  #59
Holger3.2
Holger3.2's Avatar
Sounds very good, congratulations, i'm relived!
so they really screwed my friend in Germany then...
he waited 6 month and got the wrong one delivered, with a lot of excuses and no change or money return ...
cheers
Holger
Old 07-15-2013, 07:07 AM
  #60
oysteinw
oysteinw's Avatar
cheers
Holger
Thanks, I guess I was lucky.
Quick Reply: Recommendations regarding a half-/roll-cage in a 993?
