Recommendations regarding a half-/roll-cage in a 993?
#138
I was looking, as you do, for a nice seat belt receptacle solution on Recaro bucket seats. Through another research about a nice plug n play rollcage I land on this thread, look who is complaining about not wanting to remove the sunroof, just like me
JPS (06-16-2020)
#139
While this thread is at the top, I should post an update photo of my half cage. Because goodness, my interior looked like junk when the car was under construction on page 6.
#142
Did you ever find a seatbelt solution?
#143
Yes! I took the FVD seatbelt "spacer" and mounted that. Now seatbelt receptacles are coming up between the seats and the center tunnel nicely.
I needed only that one because my Recaro mounts have the receptacle mount integrated, so I bought only the two holed rectangle metal extender, but it looks like you can't buy them separately anymore. Good thing: the price with the mount is the same as I paid for only the metal extender. I can't remember if the additionally needed bolt is included, I don't think so but check it.
https://www.fvd.net/de-de/9645210650...n-germany.html
#146
#147
I don't know , I think it is FVD fabrication but as I said, I paid the same price but for only the rectangles, so you might not find better price anyways.
#148
Thanks. I was actually hoping to thread it through the belt hole. Over the side leaves a lot of slack so the belt isn't over my hips properly. I'm not sure yours solves that?
#149
Not totally if you really want something close to stock, but I am not really thin so I don't think it makes too much difference. My plan is to add a proper bolt in rollcage and I will then probably go 4 point harnesses anyway.
