993 Forum 1995-1998
Official Tie Rod Pinning Tool Wait List Thread
Old 06-03-2017, 03:58 PM
  #241
shadow993
shadow993's Avatar
Originally Posted by hchc
Hello, please add me to the list:
shadow993
Hchc
Next up should be shadow993 if still wanted. Thx !
Tag teamed 2 cars and ready to ship the jig. Hchc, I sent you a PM.
I'm not sure who is after you.
Old 07-28-2018, 10:33 AM
  #242
AOW162435
Seared
AOW162435's Avatar
Are any of these fixtures still in circulation?
Andreas
  #243
paulkromz
paulkromz's Avatar
Back from the dead.
Who has it?
Thanks!
Old 09-10-2018, 02:15 AM
  #244
paulkromz
paulkromz's Avatar
BUMPAGE...............anyone?
Old 09-10-2018, 01:59 PM
  #245
911F1
911F1's Avatar
Paul
Did you PM shadow993 and Hchc?
Old 09-10-2018, 07:44 PM
  #246
paulkromz
paulkromz's Avatar
no - thanks for the advice!
Old 09-13-2018, 08:27 PM
  #247
paulkromz
paulkromz's Avatar
shadow993 sent it in a long time ago......
Old 12-09-2018, 01:38 PM
  #248
samurai_k
samurai_k's Avatar
Happy holidays everyone. Anyone have this tool squirreled away in your garage? I would like to borrow it. Thanks
Old 12-09-2018, 02:18 PM
  #249
samurai_k
samurai_k's Avatar
Update... confirmed with @drb and @shadow993 they no longer have the jig. @shadow993 sent the jig to @hchc
@hchc can you confirm you still have the jig or can you let us know who you sent it on to?
Thanks!
Old 12-11-2018, 05:23 PM
  #250
paulkromz
paulkromz's Avatar
bump !
who gots its?
Old 02-26-2019, 02:17 AM
  #251
samurai_k
samurai_k's Avatar
Bump... does anyone know where this kit is?
Old 04-12-2019, 11:36 AM
  #252
samurai_k
samurai_k's Avatar
TTT!
Old 04-12-2019, 02:22 PM
  #253
911F1
911F1's Avatar
Looks like HCHC was the last person. PM them. They signed in to Rennlist just yesterday. Still active
Old 04-12-2019, 09:09 PM
  #254
Garth S
Garth S's Avatar
In response to a couple of PM's received today, yes - the original jig of 2008 eventually made it back 'home'.
The pilot hole of 5/32" grew to some much larger convoluted hole a wood worm would be proud of: I dressed it up to a nominal 1/4", did a couple of local cars, and retired it to the bench.
1/4" pilot rather defeats the purpose of being a guide for a 5/16" final hole, hand drilled w/o a guide.
All the jig dimensions are in post 217 of this thread; however, to repeat, a piece of solid stock was welded to a section of 1.5" id pipe (37mm). Directly opposite this addition, a 5/32 hole is drilled through the pipe on the diameter/radial) line.
The pipe is then square cut to place the pilot 19mm (3/4") inboard from one end, and the other end cut leaving a total of 68mm pipe section (2.7").
Then split the pipe lengthwise at right angles to the pilot line .... and finish drilling the welded piece (from the inside) were the drill too short.
Viola, that is a complete saddle jig, ready to be clamped to the outer barrel of the inner tie rod, and a 5/32 pilot hole to be drilled through the inboard side of the inner rod half.
Anyway, if anyone wishes to drill a 1/4" pilot, I can again mail the original jig out. Note - I suspect that it may last a short time before requiring redressing the hole to the full 5/16"
Old 04-12-2019, 09:25 PM
  #255
samurai_k
samurai_k's Avatar
@Garth I am going to attempt to drill the pilot and final hole with my press. It is not clear to me where exactly you are to drill the hole in relation to the inner tie rod male and female ends. Can you help clarify? Eyeballing it looks like about the middle of the inner...
Thanks!
Quick Reply: Official Tie Rod Pinning Tool Wait List Thread
