Tire balancing
Moderator and 993 whisperer
Best thing, in my humble opinion, would be to take the car back to the alignment shop. If they find no fault in the balance, at least you will have a data point that will help you and your repairmen figure out what is wrong.
Ed ... can't they tell if a wheel isn't true when they bolt it to the balancing machine? Just curious ... always learning.
I did have a minor shake at a lower speed which is why I thought I would rid myself of it while installing new rear tires.
Could be a faulty machine, noob tech or, as was mentioned, a bent wheel (not likely, IMHO). Have them re-do it. If that doesn't work, ask for a refund and then go to a place that has a Hunter Roadforce machine and/or a different tech.
I assume you are balancing the 17" targa wheels in your avatar? If so, does anyone know if those are lug centric or hub centric wheels? I ask because my 1999 Toyota 4Runner had lug centric wheels and had to be aligned with a lug centric adapter at a time when most shops were using a cone-shaped, hub centric adapter. I had to go through three tire places before I could find one who had a lug centric adapter. Food for thought.
Also, kudos to you for not using all caps. Thank you.
Of the folks saying bushings ... how many miles? I have two '95s, so just curious as a matter of prevention. Thanks.
