Weird Throttle Response 993
OK so I started up my car yesterday after about 1 week of not driving it and I probably let it idle for about 20 seconds before starting off. I usually let the car idle a bit more (around 1 minute) if I haven't driven for over 4-5 days but seeing as how the manual states that you should drive it to warm it up I figured might as well do that.
Off the bat I noticed that throttle response was kind of delayed and the power just wasn't there. After about 2-3 minutes of driving it I tried to accelerate hard it but it was hesitating and it seemed like it didn't want to go past around 4k. I figured I'll just drive it normally until it is fully warmed up and then try again. After probably another 5 minutes of driving the car it was fine. I have had similar issues before when starting it cold after a few days but only between 1500 to 3000 rpm. It would feel as if the engine is revving but nothing was put down and then it would kind of kick in towards 3k. However, all of this would be gone within about 15-30 seconds and it was also when I first bought the car so I thought maybe I'm still adjusting to the 993 pedal vs my Acura. I haven't driven the car today since I thought I should post this first. Any ideas on what could be causing this? |
I'd start by cleaning your MAF. Mine developed a wicked flat spot when warm a few months after I got it-solved by pulling the MAF, with a good cleaning using CRC MAF cleaner.
When I gave mine aggressive throttle, not necessarily full throttle, it felt like it was starving for gas. When I'd let up on the pedal, it would start to come back and drive fine at crushing speeds. O2 sensors may be on the list of culprits, perhaps. |
could be a wonky cylinder head temp sensor also.
Thanks for both of your inputs. I will try the MAF sensor cleaning first, just trying to find a good diy article on this.
its easy.
1. remove air box cover...two clips 2. remove air filter...pulls out. 3. remove air box. Thats a clip that needs to be popped on the transition to the maf...flat head screwdriver works fine. Then you have a smaller hose towards the front on the bottom. loosen the clamp. Box will then come up off its mounts and out. 4. undo the electrical connector...twist off 5. undo a hose clamp holding the other side of the maf...then pull out. carefully spray with MAF cleaner...don't use carb or brake cleaner. assembly is reverse. |
Thanks quadcammer. I was thinking that since I'm going to be doing that I might as well clean the throttle body too, however, the general consensus was that the VarioRam should be removed...
Originally Posted by eddie_993
(Post 10176964)
I would also make sure that the Varioram servos are all working, just turn on the key and the flaps will move if there is vacuum. You might want to test after a drive.
Also make sure both distributors are still synced and working. |
One of the Distributers???
Originally Posted by Stealth 993
(Post 10177323)
Originally Posted by Ed Hughes
(Post 10180981)
That there is all that high-tech stuff I don't have on my '95....
The first thing I'd be doing is checking the distributors to make sure the belt hasn't failed.
Originally Posted by Steve Weiner-Rennsport Systems
(Post 10181190)
Thank you for all the input guys. I will check/clean the MAF sensor and also check the distributor belt.
If the distributor belt is the culprit, what would it look like? Would it just have some rips/tears or would it be completely torn? |
Hi,
when the twindistributor is the reason for the powerloss, then it is a broken belt in most cases... Chris |
