993 turbo wheels on a C2
Will 993 turbo wheels fit a C2? Whats the difference in sizes (besides 17s and 18s). and if they will not bolt on what is need to make them fit?
Thanks guys, Chad |
No they won't fit without some rear fender work. Rear offset is different. You'll have to roll the fenders and aggressive neg. camber
thanks
Chad,
If you are asking if Turbo Twist styled wheels will fit, they also come in offsets that fit C2. See avatar. |
Originally Posted by 95_993
(Post 10138104)
Chad,
The front fit between the two cars is the same. Turbo wheels will need 15-20mm spacers to fit a narrowbody.
(Post 10138104)
Chad,
Originally Posted by damon@tirerack.com
(Post 10138175)
refer for the spacers...
(Post 10138175)
Originally Posted by darkens
(Post 10138001)
Thanks guys, Chad |
There are 18" Turbo Twist wheels Hollow and Solid for Narrow Body C2's with no spacers required. Direct fit, no spacing issues.
By Turbo wheels, you mean WB offset right? If you want Turbo twists for your C2, the NB rears with ET 65 should fit no problem at all.
Originally Posted by Nurburger
(Post 10138386)
Tut tut tut Damon.... Other way round - WBs need a 15-20mm spacer to fit NB wheels.
Originally Posted by Chris M.
(Post 10138401)
Porsche made hollow and solid turbo twist wheels that will fit your C2 without any modifications or spacers. The part number is 993.362.140.01.
Chad |
Here is a summary of the wheels you are talking about. They are called “Technology” wheels…commonly referred to as “Turbo Twist”. They come in a hollow spoke and solid spoke version. I have the hollow spoke version on my '97 narrowbody (C2). They bolt directly on...no spacers required.
Hollow spoke "Technology" wheels: 8 x 18 - 993.362.136.00 - ET52 - 19.95 lb (front) 10 x 18 - 993.362.140.01 - ET65 - 23.36 lb (narrow body rear) 10 x 18 - 993.362.140.00 - ET40 - 25.13 lb (wide body rear) Solid spoke “Technology” wheels: 8 x 18 - 993.362.136.01 - ET52 - 25.57 lb (front) 10 x 18 - 993.362.140.04 - ET65 - 29.32 lb (narrow body rear) 10 x 18 - 993.362.140.03 - ET40 - 31.08 lb (wide body rear) |
