993 Forum 1995-1998
9m93RS Clubsport #5 from USA origin Carrera 4
Old 03-15-2013, 10:51 AM
  #121
Bill Verburg
Bill Verburg's Avatar
Originally Posted by NineMeister
Already in there Bill, there's a photo a few pages back.
I don't know how I missed that
I also like the simple rollbar mounts for the 3 point belts
Old 03-15-2013, 06:29 PM
  #122
Captain Ahab Jr.
Captain Ahab Jr.'s Avatar
Colin, I may have missed it but why the seam welding in this area?
Old 03-17-2013, 03:07 PM
  #123
NineMeister
NineMeister's Avatar
The factory spot weld the tow-eye reinforcement plate to the front panel before welding the front panel into the tub. When you retro-fit the reinforcement you can spot weld the top effectively but not the bottom, hence Owen chose to seam weld the plate to ensure a full strength join.
Old 03-18-2013, 08:08 PM
  #124
NineMeister
Shot a few photos today of Owen and Neil doing the final preparation of the boot aperture and interior areas in time for first paint tomorrow.
Old 03-18-2013, 08:53 PM
  #125
NineMeister
Detail shots of the aluminium filler used to block the rust pits in the corners of the windscreen aperture; the PU sealant bead on the front wing to inner wing joint which will be painted over when we paint the front compartment.
Old 03-19-2013, 09:46 AM
  #126
coltj
coltj's Avatar
Hi Colin,
What are the two tubes, visible in the 7th photo of post #104, extending beyond the tunnel?
Thanks.
Old 03-19-2013, 10:06 AM
  #127
Nollie
Nollie's Avatar
Originally Posted by coltj
Hi Colin,
Thanks.
E-Brake cables if I'm not mistaken.
Old 03-19-2013, 10:49 AM
  #128
NineMeister
Hi Colin,
Thanks.
Nollie is correct, they are the integral steel guide tubes for the two handbrake cables.
Old 03-19-2013, 11:37 AM
  #129
coltj
coltj's Avatar
Thanks. That makes sense.
Old 03-19-2013, 12:58 PM
  #130
Bill Verburg
Did you guys reinforce the shock towers in any way besides additional welding of the seams?
Old 03-19-2013, 05:36 PM
  #131
NineMeister
Yup.
Old 03-19-2013, 05:39 PM
  #132
NineMeister
Big day in 9m Panelcraft today. First job was to clear out the booth and prepare the shell for painting.
Old 03-19-2013, 05:41 PM
  #133
NineMeister
Almost forgot about this detail. The owner is 6'5" tall so we have lowered the drivers seat mountings on the floorpan to gain additional helmet clearance to the cage (and lower the CoG for improved handling).
Old 03-19-2013, 05:44 PM
  #134
NineMeister
Take one roll of masking paper and several rolls of tape, Then get vacuum cleaner and airline to bblow/suck out debris from all the cavities. You can guarantee that anything left in the shell will blow out and ruin the paint if you don't do this thoroughly!
Old 03-19-2013, 05:47 PM
  #135
NineMeister
Etch primer on bare metal follower by two light coats of grey primer on everything exposed:
Quick Reply: 9m93RS Clubsport #5 from USA origin Carrera 4
