9m93RS Clubsport #5 from USA origin Carrera 4
#286
Yes, it's the cam.
#287
Such a nice build, very interesting to see how your friend Wayne has been able to massage the motronic into working with this heavily evolved engine spec!
BTW love the smurf blue, the owner should ditch the seats and fit Alloy Kirkey seats painted body colour;-)
One day....lottery....etc.
#289
Our dyno measures rolling losses, adds it to the rear wheel numbers and then corrects to DIN standards so we have no control over the cf for the runs, but 350hp is typical of this conversion on the 9m dyno though.
#290
Patience is a virgin.....
Latest dyno plot attached, 350hp & 429Nm. The engine is what we call a 9m 993 Varioram +3 specification which has rods, 102mm 9m pistons & cylinders, 9m billet heads, 9m Sport cams, 9m Sport valve spring set, ported Varioram intake with 100 cell cats. The air pump system has been partially deleted (not required in Europe) and the 88pin ecu fully remapped. The rev limit has now been raised to 7500rpm.
(Before anyone asks, this set up is fine for European legislation I don't think it would be suitable to pass US engine check standards, hence we are looking at other solution at the moment for the US market.)
Toyo R888 are road legal so that's how the 9mRS will leave our premises on its way back to Europe. Fronts are 235/40 rear are 285/30 on 8.5" & 10" x18" Rays TE37 rims. We had to roll the rear arches to get the 285 tyres to clear.
350 bhp & 429 Nm is really satisfying to see
The reason I have decided not to put ITB's on and remap with Motec is that I would probably fail an MOT. When we drive at local track day events we currently enjoy the cover of our insurance but this require that we have a car that is road legal.
If I, with this current set up, installed ITB's, Motec and a more purpose full header what improvements would you expect in regards to power and torque? and at what rpm's assuming that I stay with the rest of the engine as is?
#292
This is pretty much the same spec engine but with 9m Race cams, ITB's and Motec. Runs stock Bischoff 993 heat exchangers & 100 cell cats. It makes 400hp.
#293
Nice power and I personally prefer to keep it simple, close to the way Porsche intended.
The car looks great, nice work...maybe it's me and having been around Rs's for too long...BUT why would anyone keep the headlamp wash...on a car where you have replicated so many RS details, it totally stands out?
Each to their own I assume.
I hope the new owner has a lot of fun with the car!
#294
Colin. With the GBP so weak at the moment your upgraded engines are looking excellent "value". To replicate a similar set up as you mention above with ITBs etc what are we talking ballpark - 25k+ GBP?
#295
The reason the headlight washers are still there is because it is requiered by law in Sweden to have them and they where original on the RS and RSCS sold new in Sweden as well, so it is to keep the car original and to pass MOT:-)
I do look forward to drive with my friends who have original RS cars and I kind of expect the 9M version to have an edge, time will tell!? :-)
#296
Yup, you're right in the ballpark for the engine. Need to allow for the Motec on top though, so for an ITB engine with a full custom engine harness it will set you back another £5k.
#297
I assume if you have fitted R888 tyres that the car is not going to run on the road?
I'm looking for a tyre that I can drive to track days with and then on track but which won't wear at a alarming rate. (I use R888 on my 968 but they fit in the back of the car with no problem...not an option for the 993)
How does a 993 feel on the R888 tyre? (I think they do hard and soft from memory)
This has been a good thread.
Ken
Ken
I used to drive on Michelin Pilot Sport Cup but Colin suggested I try Toyo R888 in 2009 and it was a good suggestion!
The reason is that they have about the same grip and life but when you are on the edge of the grip they let go in a much more forgiving way such that, me being not a professional race driver, I can drive the car on a bit of a drift.
The MPSC had a tendency to loos the grip in a more dramatic way and hence I felt it more difficult to catch the car. They are also superior to the MPSC if there is a bit of water on the road where the Michelins where a nightmare!
In Europe they are street legal why we can use them to drive to and from the tracks. If you run a lot of camber then it will of course wear them down on the inside is you spend a lot of time on the highway but you can perhaps take a more interesting road to the track and then you may get away with it
#298
Hi Ken,
For my Speed Championship winning seasons I switched to Kuhmo Ecsta V700 V70A because they were available in a different compounds, my choice being medium for the hillclimb & sprint events I did. The V700 are another very good choice (and fairly competitively priced) but do require the car to be set up accurately and need a smooth driving style to get the best from them. For trackdays you would need the hard compound version.
#299
I've run MPSC for the past 5yrs, been pretty happy w/ them except in the rain, which I don't do anyway.
Yesterday was the first day trying NT01, I have to say I was impressed. Only issue was they seem to build pressure a lot more than MPSC.
#300
Bill. If you think NT01 are good you will LOVE Hankook 221s - also called TD (you will have to hunt down a supply over there). Theres a detailed independant test using a 911 GT2 on the web which makes good reading (the test was in the States). The took the NT01 crown in the recent World Speed Time Attack comp....
