Wheel fit question
Wheel fit question
Hello all,
Happy New year to you all
I am looking at the BBS wheels in the for sale section. Can anyone confirm that they will fit on the 993 NB?
Front Wheels: 18 X 8 1/2 Offset 56mm
Rear Wheels: 18 X 10 Offset 65mm
Thanks as always
Thanks as always
They should fit just fine. ET65 is standard rear offset for NB, and IIRC, ET52 is standard for the fronts, so those front wheels will be offset 4mm further in (away from the fender), and probably allow you to run slightly wider tires.
oe front is 8ET52
I use 8.5ET54, Bob Gagnon uses 8.5 ET56, 993Cup used 8.5ET53
oe rear is 10ET65, they fit perfectly
