Best garage floor coating?? Chime in please!
#46
Tile longevity in a garage falls to two factors: the density of the tile (a vitrified porcelain is the best), and the quality of the installation. Any tile, due to it's dimensions, is relatively brittle, so the quality of it's bedding is what will keep it from cracking or breaking. Even softer material, like Quarry or Clinker Tile can last, if bedded correctly, though it will be prone to chipping.
If I was tiling my garage, it would be a fully vitrified porcelain, with rectified edge, and set butt joint. This would allow for easy rolling around of jacks and placement of jack stand.
That being said, Jack Olsen will be along any time to show his garage, which was done with an economical tile, and installed by himself, and it looks great.
#47
Some very impressive floors. If you intend on using your garage for working on your car at all I would think these spotted pattern floors would be a nightmare for finding dropped nuts and bolts. The last thing I would install personally. But then again I don't see any tools in most of these garages.
#49
#51
If I had my way I would have a nice storage garage with the fancy floor and a separate working shop with a plain painted floor.
#52
Believe it or not, it's not that bad. Broken glass would be a nightmare, but most nuts/bolts/gaskets/etc. contrast pretty easily. Not sure if you were trolling with your tool comment, but I have plenty of tools in my "fancy" garage. I just don't service my own car since I don't have a PIWIS nor the time to do maintenance on it....
My garage floor was painted by the previous owners and for a reason that escapes me this cement floor paint has a sort of speckled top coat that looks like Jackson Pollack was here. It drives me up the wall because it's as good as camouflage for dropped fasteners and the like. Feel like I need a metal detector to pick things off the floor. Maybe one day I'll paint the floor a nice bright yellow with a big black and red Stuttgart crest in the middle!
#54
nathan1 -sorry to hijack this thread but can you tell me more about your lift?
#56
I never get the need to pretty up a shop floor - my floor is, well, concrete and proud of it. No treatments, no epoxy, no tiles, no strips, nothing - but concrete. Its take 20+ years of car maintenance, engine drops, tools and heavy objects dropping on it and you know what - its held up! I scrub it once a year and make a pass with the 4000pst 13HP pressure washer, cleans up and its ready for the next year. No worries, no fuss.
Its bad enough I have to watch the car as not to ding/scratch/damage anything, but I do not want to watch the floors.
(oops - ok flame suit on!).
cheers,
Mike
cheers,
Mike
#58
I think this is aimed at home garages and that's why it's all gone this direction. My home garage is pretty, my shop and lift is for working and not all about aesthetics but is always clean bare concrete.
#59
I like the ideal of a smooth surface, either polished concrete or tile appeal, so that it is easy to sweep out, or hose out. I think my concrete is too porous to polish nicely, not sure. JD, I like that finish you've got.
