Installation thread for KONI FSD suspension - UPDATE #1
#91
The drop link dust covers needed replacment.
When removing the drop link be sure to use some liquid wrench at the hub and down below. These are exposed to the elements and cake up allot of crud. You don't want to strip these - it would be a real PIA.
I found a great source on EBAy for these (exact fit and inexpensive). For some reason these are hard to come by in the US:
http://www.ebay.com/itm/150745546351...84.m1497.l2649
Here is a better shot of the refinished caliper. This one was in pretty bad shape - peeling and dull.
Here is a picture on the dust covers and rubber stoppers that needed repacment - there is one of these for each strut/shock. The covers run @ $8 each and the stoppers are $16
The rubber gasket for the struts (black "Germany" rubbers) sit atop the strut tower.
Also, rember that the upper part of the strut is directional (red dot to the front) and I believe, right and left. Be sure to label these as you take them out upon removing the old struts.
Here is a picture on the rear shock partially installed:
Mysuspension arms still need to be cleaned up a bit.
#92
rob
#93
Any warranty case is handled through us and we solve the issue with Bilstein or Koni. We have quite a good relationship with these companies.
For Bilstein, we "invented" the HD with extra threads (now called B6XT) which is now the default 993 shock for the US market.
We helped Koni with them with the development of the Koni FSD for the 964 and currently with another project ....
#94
At the time I removed the old struts. I noticed the front drop link covers were pretty messed up.
I found some replacements off EBAY.
You have to make sure to get the correct diameters when ordering them.
bottom 25 mm
top 10mm
height 24 mm
The factory cover is held on the top by an O ring and on the bottom by a metal spring type ring. One you remove the metal ring retaining the OEM cover will be easy to get off. The replacement unit uses the larger rubber O ring shown which works well.
Before:
After (after cleaning the metal with some degreasing solvent on a rag, under the rubber cap is alot of grease which you want to leaving in place.)
Reinstalling them is easy.
bottom 25 mm
top 10mm
height 24 mm
Before:
#98
The front struts are all installed.
59 ft pounds on the top mount
88 ft pounds on the small bolt down below
157 ft pounds on the large bolt
I inspected the control arm bushings and they are like new - car has @ 26K on it. Rubber is like new and there is no play.
The rubber on all of the boots was "as new" with the exception of the drop link boots which had taken a beating.
The one rear shock is installed (with the exception of the drop link).
I just got word from KONI thay are sendingme the replacment one today - awesome customer service.
In the next weeks I should have the suspension all done, wheels on the car, and ride height set. It's then off to an alignment.
I mounted my turbo wing in the meantime, I decided to use a custom decal as opposed to a factory insignia.
#99
Great work !!
So the Brit ebay seller will ship to the US ??
Final cost ?
Final cost ?
#100
The British EBAY seller that sold me the new dust covers for the drop links will ship to the US.
The total cost for a pair (shipping and PayPal fees include) was @ $12.
#102
That is hilarious. I looked at it late last night, and thought it looked off, like the Font is off. But, it is the spelling, perhaps, that makes it look wrong.
#103
Easy to do, after all the years I still have to think twice.
I used a vinyl decal on my duck tail. Various sizes available from these guys: http://www.acromann.com/index.php?ma...sort=2a&page=2
#104
I have not been following this thread - good work so far.
Honestly, I do not like that sticker on the tail, it's does not look right with the rest of the car, I like the factory script much better. It may also look odd on a Turbo tail as well ( I am used to seeing "Turbo" there - haha).
Cheers,
Mike
Cheers,
Mike
#105
Oh, well - time for a new decal (they peel off anyway).
I think I will loose the red accent, use a thinner script, and just balck - and use the correct spelling this time.
I have to adjust the gap on the driver's side - it is off a bit in the pic.
