993 Forum 1995-1998
Centre air vent removal
Old 10-04-2012, 06:19 PM
Malibu101
Malibu101's Avatar
Angry Centre air vent removal
I need to replace my centre air vent and before I try to remove it ( in a way I am not to sure and will probably damage it ), does anyway know if it just wiggles out, push on the left or right side first etc etc...
Thanks for any help.
Old 10-04-2012, 09:39 PM
NC TRACKRAT
NC TRACKRAT's Avatar
It will really fight back. Thanks to RL, I determined that, in order to easily access the antenna booster lead when replacing the windshield, it's best to remove the upper dash. That requires pulling the center vent to access the nut that holds the dash in place. Use both hands (thumbs and forefingers) and just pull straight back with all your might and pray. It snaps into place quite easily but getting it out is another matter.
Old 10-04-2012, 10:15 PM
pp000830
pp000830's Avatar
Received 1,441 Likes on 1,015 Posts
Default Plumbers rules seem to apply to Vent removal
If it's stuck force it, if it breaks it needed replacing anyway!
Old 10-04-2012, 10:26 PM
jhummel68
jhummel68's Avatar
There are small metal "clips" 2 on top 2 on bottom. They allow you to push it and it locks into place but to remove you have to be able to hold all of them in the "retracted" position. You might be able to use a small finishing nail in each one to hold it retracted. If you try pulling on it there will probably broken plastic when you're done. Saw it happen once.
Old 10-04-2012, 11:52 PM
aribop
aribop's Avatar
You can access the center nut by removing the clock. There are only two metal clips on the top of the vents but it is much easier to remove the dash top and then pop the vents out.
Old 10-05-2012, 04:24 AM
911PERVY
911PERVY's Avatar
You have 2 answers here!
The windscreen vent and the passenger centre vent
Both good answers, just make sure youre working on the correct vent!
Old 10-05-2012, 04:39 AM
Malibu101
Malibu101's Avatar
Thanks all for your input. Will head down to the garage tomorrow morning and give it a go!!
Old 10-05-2012, 10:09 AM
techman1
techman1's Avatar
Another vote for not just yanking on it. I used 2 strong toothpicks, wedged the top 2 clips down, gave it a tug and out it popped.
The foam seal where the vent mates to the plenum in mine was dust. Used window/door foam strip with sticky on one side to replace it. Seemed to increase airflow.
Old 10-06-2012, 12:09 AM
600RR
600RR's Avatar
Get a couple of thin putty blades to hold down the clips. Use a flashlight to see them. DOn't just yank it out. If you do it will break the clips. However, I have had one in with broken clips (first time I did it) and no problem. It fits snugly and doesn't rattle. Second time I pushed the clips down.
Old 10-07-2012, 05:08 AM
Malibu101
Malibu101's Avatar
Tried it today with no luck. Got the two top clips loose enough to have the top half of the vent come out but there was no way the bottom part was going to give. Couldn't see where the clips were on the bottom part of the vent though. If I have the top clips loose, should I just give it a good old tug?
Old 10-07-2012, 12:06 PM
techman1
techman1's Avatar
The two bottom clips are detents that stick out, with no way to take tension off like the top. They should press inward as you pull the vent out.
Quick Reply: Centre air vent removal
