AC not cold
AC not cold
gents,
my AC is not blowing cold air...is it difficult to re-charge?
does anybody have any recommendations for a p-car shop in La Habra/Fullerton or near please?
thanks
thanks
paid $140 for a vacuum test and re-charge...was advised to lookout for leakage from front left fender area...feel like I over paid but getting cold air is a relief in this summer heat...
thanks again for the help/info as always chaps
that's not bad. i paid a $45 for leak test and recharge was another $170. Luckily, the $45 counted towards the recharge. the shop should use a sniffer to detect if there is a leak. any leak should be repaired before your freon goes out.
If no one chimes on a shop, if you are a PCA member you can always contact
your local zone techie and ask:
http://www.pca.org/
"Filler Valve" .... is the Service Valves, located on the compressor manifold or immediately adjacent to it on the refrigerant lines attached to the compressor.... depending upon which model you have.
Calling it a "Filler Valve" may lead a naive reader or DIY into thinking that is all its there for or if you have a problem with the AC you simply 'fill it up'.... LOL.. .NO, NO, NO.
The Service Valves are used to Add and Remove Refrigerant, Test the Pressures and Pull a Vacuum.
You just don't "Fill it up'... no, no, no.
