Door Sound Insulation Repair
Old 11-01-2015, 06:20 PM
  #31
bruce7
User
bruce7's Avatar
Originally Posted by Kmassed002 View Post
You could always put back on the factory moisture barrier and put the Dynamat on the door panel instead.
I guess I wasn't clear. I would definitely use the Dynamat on the inside of
the door. Great stuff. Then use the factory moisture barrier on the outside
panel instead of VB2. No problem with VB2 as a moisture barrier. Just not
designed to be repeatedly removed and replaced like the factory barrier.
bruce7 is offline
Old 11-04-2015, 07:58 PM
  #32
s2racer
s2racer's Avatar
Default Door sound insulation
Thanks guys....good information. I'm picking up some Dynamat later this week, and reusing the factory barrier.
Appreciate your insight.
Marc
s2racer is offline
Old 01-09-2016, 01:07 PM
  #33
s2racer
s2racer's Avatar
Default Old insulation removal
Just getting back to this project (now that winter is finally here in FLA :-)). Any tips for removing the old door sound insulation? Most of it comes right out, but there is some remaining that must have been installed with epoxy.
thanks
Marc
s2racer is offline
Old 04-06-2016, 03:46 PM
  #34
bruce7
User
bruce7's Avatar
Default Updated with new link to photo album
Here is the new link to the Google photo album:
https://goo.gl/photos/GWesmR8jCQkmrfog6
-bruce7
bruce7 is offline
Old 04-07-2016, 06:26 PM
  #35
Jlaa
Jlaa's Avatar
Bruce7, thanks for going through and documenting this. Very thorough - I like the narrative about the theory and the reasoning behind the choices made --- very "Cook's Illustrated" esque --- I mean that in a good way.
I will be pulling my door panels off later this year to cover them in leather and will attempt to duplicate your project just "while I am in there".
Jlaa is offline
Old 04-07-2016, 06:51 PM
  #36
bruce7
User
bruce7's Avatar
Thanks Jlaa! Look forward to seeing the results of your project.
bruce7 is offline
Old 04-07-2016, 09:24 PM
  #37
Greg Bell
Tip - while you're in there remove the black plastic cover over the central locking mechanism secured by two countersunk screws located above and below where the door locks to the body and give it a good lube with something like WD40.
I've just done mine as the trigger on the outside passenger door was stuck hard against the inside of the door handle making it inoperable from the outside.
For a while I thought I was up for a new lock but WD40 fixed it and the locks are once again smooth and notch free.
Greg Bell is offline
Quick Reply: Door Sound Insulation Repair
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
